It is currently Sat Nov 21, 2026 2:50 am
 Post subject: How to turn the crank?
PostPosted: Sun Mar 02, 2008 4:05 pm
What is the best way to turn the crank if you can't bump it with the starter.
It looks like I can get a big bolt in the pulley. Does anybody know what size bolt to use (if this is the best method)?
The engine is a 68
PostPosted: Sun Mar 02, 2008 4:27 pm
Car Model: 63 Dart 81 D150
I don't recall exactly what size it is, but I know it is the same as an LA engine if that helps at all. I also know the LA bolt has a 1-1/4" head so you need that size socket.
TopHat
PostPosted: Sun Mar 02, 2008 4:33 pm
Read THIS
PostPosted: Sun Mar 02, 2008 4:55 pm
Honestly, our low compression little mills should turn pretty freely by hand. just grasp the balancer and the belt and inch it along. If you take the plugs out it's even easier.
PostPosted: Sun Mar 02, 2008 5:06 pm
Thanks!
BTW, the pistions are 0.60 over bore and high compression, and the belts are off. I tried to muscle it around but I'm old and weak.
PostPosted: Mon Mar 03, 2008 4:39 pm
Thanks!
With the plugs out you have no compression, I would be a little concerned if you can't move it at all. Try the bolt in the end of the crank method or maybe a strong neighbor that likes beer.
PostPosted: Mon Mar 03, 2008 8:35 pm
My damper has tapped holes on the perimeter.
I put 3 grade 8 bolts into those holes and then use a wrench on the bolt heads to turn the engine over
Users browsing this forum: Amazon [Bot] and 5 guests
