| Piston notching? https://slantsix.org/forum/viewtopic.php?t=27637 |
| Author: | pinkiedog64 [ Tue Mar 04, 2008 1:00 pm ] |
| Post subject: | Piston notching? |
I'm building a slant six (225) for my '64 D100. The head has been milled .100" and I have .465" 280 deg cam with 1.7 intake/ 1.44 exhaust valves. The block has not been decked yet, but I will assume that it needs it. Assuming the block is decked the "normal" amount, do you guys think I'll have to notch the pistons for valve clearance? If I do have to notch them, how do I konw how much to notch? I know how to measure valve to piston clearance with a lump of clay and lettinght valve make an impression in it and measuring, but that only works if the vlave does not hit the piston. How do I figure how deep to go with the cuts? |
| Author: | Doc [ Tue Mar 04, 2008 1:05 pm ] |
You loosen the valve lash until you get the needed clearance, measure the lash, add a little more for "insurance" and machine the notches. Be sure there is enough thickness in the head of the piston before cutting metal. DD |
