| J bolt installation on fuel tank https://slantsix.org/forum/viewtopic.php?t=27676 |
| Author: | 74DartSport [ Thu Mar 06, 2008 4:54 pm ] |
| Post subject: | J bolt installation on fuel tank |
I'm installing a new fuel tank. The j bolts that hold the tank in place originally had this soft gel-like substance on the bolts and on the brace when I removed the old tank. In my opinion, that must have been for noise suppression. Anybody know what it was? Should I put it on the j bolts after I reinstall tank? What was it? Could it have been part of the undercoating the dealer put on the car when I bought it in 1974? |
| Author: | DusterIdiot [ Thu Mar 06, 2008 5:18 pm ] |
| Post subject: | Yep... |
Quote: Should I put it on the j bolts after I reinstall tank?
Yes and clean the bolts up and use a bit of antiseize or WD-40 when tightening them so they don't freeze up on you... I've seen the bolts covered in undercoating, mud, grease, grime... most stock applications they were just left as-is and became rusty...-D.Idiot |
