| Hey hardcore racers! (Damper question) https://slantsix.org/forum/viewtopic.php?t=2771 |
| Author: | dschumers [ Mon Oct 15, 2001 8:00 pm ] |
| Post subject: | Hey hardcore racers! (Damper question) |
Just taking a poll here, what kind of aftermarket balancer is everyone using? I'm probably going to get one this winter, so I'm shopping for suggestions. Thanks! Dennis slantzilla@excite.com |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Oct 15, 2001 8:51 pm ] |
| Post subject: | Re: Hey hardcore racers! (Damper question) |
: Just taking a poll here, what kind of : aftermarket balancer is everyone using? I'm : probably going to get one this winter, so : I'm shopping for suggestions. Thanks! Dennis I am using the Fisher Damper. I shortened the hub about 3/4" so it tucks up to the T-cover. I run a flat pulley on the front to drive my w.pump & alturnator. DD |
| Author: | Dave M [ Mon Oct 15, 2001 9:57 pm ] |
: Just taking a poll here, what kind of : aftermarket balancer is everyone using? I'm : probably going to get one this winter, so : I'm shopping for suggestions. Thanks! Dennis I am using a Fluidampr off a 440 for my race car. Also use the front crankshaft seal from the big block. Had to make the pulley to drive the oil pump. Another racer out here uses a ATI damper also from a big block. Both work fine for racing at RPM's around 6000. The only thing I noticed is that the fluid damper you must warm up the engine to get the oil warm in the damper before it works correctly. damuel@kalama.com |
| Author: | Will [ Mon Oct 15, 2001 10:01 pm ] |
Dennis Did you forget to use the search function? I use a fisher but some do use a big block one. Will Quote:
: Just taking a poll here, what kind of : aftermarket balancer is everyone using? I'm : probably going to get one this winter, so : I'm shopping for suggestions. Thanks! Dennis slantsix@netzero.net |
| Author: | Darrin [ Tue Oct 16, 2001 3:24 pm ] |
: I am using a Fluidampr off a 440 for my race : car. Also use the front crankshaft seal from : the big block. Had to make the pulley to : drive the oil pump. Another racer out here : uses a ATI damper : also from a big block. Both work fine for : racing at RPM's around 6000. The only thing : I noticed is that the fluid damper you must : warm up the engine to get the oil warm in : the damper before it works correctly. Do have to do any kind of special machining to big block dampers to make them fit and/or function? Darrin dartman225@webtv.net |
| Author: | Will [ Tue Oct 16, 2001 10:24 pm ] |
: Do have to do any kind of special machining to : big block dampers to make them fit and/or : function? Darrin no slantsix@netzero.net |
| Author: | Dave M [ Wed Oct 17, 2001 8:01 am ] |
: Do have to do any kind of special machining to : big block dampers to make them fit and/or : function? Darrin Just put the new seal in,bolt a pulley on and adjust your spacing for the alternator/water pump. The new damper (both types) are thicker than the stock unit. But well worth the effort. damuel@kalama.com |
| Author: | Darrin [ Wed Oct 17, 2001 6:38 pm ] |
: Just put the new seal in,bolt a pulley on and : adjust your spacing for the alternator/water : pump. The new damper (both types) are : thicker than the stock unit. But well worth : the effort. Thanks for the info! It will definately make shopping alot easier. Does it need to be from any specific year or size of big block? Darrin dartman225@webtv.net |
| Author: | Dave M [ Wed Oct 17, 2001 9:51 pm ] |
: Thanks for the info! It will definately make : shopping alot easier. Does it need to be : from any specific year or size of big block? : Darrin Darrin it will fit a early 383-426-440 that is internally balanced. Fluidampr only lists two for the mopar line. The small block and big block. damuel@kalama.com |
