Cutting the head
https://slantsix.org/forum/viewtopic.php?t=27723
Author:  WyldeBill6 [ Sat Mar 08, 2008 8:59 pm ]
Post subject:  Cutting the head
If you shave the head down .10, do you have to get different pushrods?
Wylde Bill
Author:  slantzilla [ Sat Mar 08, 2008 9:02 pm ]
Maybe, maybe not. You will have to check upon reassembly though. :shock:
Author:  Greg Ondayko [ Sun Mar 09, 2008 6:49 am ]
If you shave it .100" and retain a stock cam - - most likely.
If you go to a higher lift cam maybe not; the adjusters will take up the extra length.
High Lift cams have smaller base circles.
Author:  70valiant [ Sun Mar 09, 2008 10:18 am ]
I didnt need shorter push rods on mine. Be careful and cc the head first. my cr is now 9.8:1 and i have to run 89 octain fuel.
Author:  Aggressive Ted [ Sun Mar 09, 2008 10:48 am ]
I cut my head and block for .10 and reground the stock cam to a higher lift. The stock push rods were right on the money.
Author:  WyldeBill6 [ Sun Mar 09, 2008 12:27 pm ]
Post subject:  Erson 270 cam
I'm probably going with the Erson 270 cam to give it some more punch since the car is pretty heavy. Four doors to move.
Wylde Bill
Author:  70valiant [ Sun Mar 09, 2008 12:29 pm ]
my 4-door is under 2900 pounds
Author:  WyldeBill6 [ Sun Mar 09, 2008 12:34 pm ]
Post subject:  My four door
My four door is a 330 B-body. A bit more than your A-body in sure.
Wylde Bill
