| 73 carborator troubles???? https://slantsix.org/forum/viewtopic.php?t=2776 |
| Author: | Wayne Sellers [ Wed Oct 17, 2001 5:07 pm ] |
| Post subject: | 73 carborator troubles???? |
I have a 73 duster ,and just rebuilt the 1 barrell holley on the 225 slant 6. It idles and pulls decent, but i have the ideling screw turned just about all the way in .If i back it off it wont run.If anyone can please help. hillbillygirl@triad.rr.com |
| Author: | Doc [ Thu Oct 18, 2001 5:37 pm ] |
| Post subject: | Re: 73 carborator troubles???? |
: I have a 73 duster ,and just rebuilt the 1 : barrell holley on the 225 slant 6. It idles : and pulls decent, but i have the ideling : screw turned just about all the way in .If i : back it off it wont run.If anyone can please : help. Fuel is "leaking" into the idle circuit. This can be caused by a loose "swedge plug", loose or leaking valve body / gasket or a mis calibrated "economiser valve". DD |
| Author: | WhaleMstr [ Sat Oct 20, 2001 12:05 pm ] |
Doc - could you elaborate a little on this please - or someone else maybe? Thanks, Dan gramma@dm-tech.net |
| Author: | Doc [ Sun Oct 21, 2001 10:53 am ] |
| Post subject: | Re: 73 carberator troubles???? |
: Fuel is "leaking" into the idle : circuit. This can be caused by a loose : "swedge plug", loose or leaking : valve body / gasket or a mis calibrated : "economiser valve". : DD Take the float bowl off a Holley and you will see it's "valve body" (really a fuel metering block)and this is where all the fuel is regulated to suppoet the different fuel "circuits". (idle , cruze and power) These blocks have a bunch of small passageways, check-balls, air bleeds and plugs so any clog, loose part(s), a crack or warp, corrosion or leaking gasket can cause trouble. 1920 metering blocks are fussy things and hard to service, best to "swap-in" a different one then waste a bunch of time troubleshooting / repairing one that is not working correctly. DD |
