| Valve Springs https://slantsix.org/forum/viewtopic.php?t=27761 |
| Author: | the black sheep [ Tue Mar 11, 2008 3:47 am ] |
| Post subject: | Valve Springs |
HEY ALL THE BLACK SHEEP HERE AGAIN i've just been given some elgin vavle springs apprently the fit slant six i looked up the specs and i am not sure there 340 v8 with damper ? i tryed them aginst a retaner and it seems to hang over the outside by quite a bit .. like 60" all the way around do i need a different retainer ?? your baa ing the black sheep |
| Author: | 1969ronnie [ Wed Mar 12, 2008 7:04 am ] |
no, even the big block springs do that on the hp setups. ron |
| Author: | the black sheep [ Thu Mar 13, 2008 1:19 am ] |
| Post subject: | Retainors |
HEY ALL i am trying to find the reson my sping judt dont look right with the retionors ive got ... the outsdie size ive got is 1.494ish with a I.D of 1.080 yours the black sheep |
| Author: | 1969ronnie [ Thu Mar 13, 2008 6:29 am ] |
hi black sheep, the inner dia is the same on the stock springs and the 340 springs (mopar p4120249 red with a damper)i know you have elgin, but they are the same as the 340 springs. to sit properly on the 8 degree spring retainers. . the wire dia is thicker on the 340 springs with less coils . to keep the inner dia the same to fit the retainer ,the spring od goes from 1.39 stock to 1.50 od ,so the spring overhangs the retainer all around , but is centered inside on the retainer. ron |
| Author: | Doc [ Thu Mar 13, 2008 9:29 am ] |
Don't worry about a little spring exposure around the retainer, they work fine that way. Carefully check the clearance between the top of the valve guide and the bottom of the retainer, around the keeper area. This tends to hit when using a higher lift cam. DD
| Author: | Wizard [ Thu Mar 13, 2008 10:28 am ] |
All valve stems wiggles like twanged strings. So keep this in consideration also. I saw a high speed video of valve vibrations while ago on youtube. http://www.youtube.com/watch?v=i_NpzU4p ... re=related Cheers, Wizard |
| Author: | dank10fenny [ Thu Mar 13, 2008 2:15 pm ] |
crazy video. and nice rocker arms doc... |
| Author: | the black sheep [ Tue Mar 25, 2008 2:00 am ] |
| Post subject: | Early Retainer |
HEY ALL i got given a slant head for helping a guy rebuild his 383 . not fun too many pistons ,,,,it a pn220635 part number thing but the retainers are different to the other ones`ve got there alot thinner (55-60"thou thick) and the 340 spring ive got fit a lot better only .30"thou overhang .. i am a little worreid about how thin they are .. the black sheep |
| Author: | Doc [ Tue Mar 25, 2008 9:01 am ] |
I have never-ever broken a spring retainer. What are your spring pressures, on the seat and at full valve lift? DD |
| Author: | the black sheep [ Wed Mar 26, 2008 6:32 am ] |
HEY DOC HERES THE SPECS ...ITS A LINK TO ELGIN .. http://catalog.elginind.com/app/Engine_ ... lve+Spring |
| Author: | Doc [ Wed Mar 26, 2008 9:09 am ] |
Quote: 91-101 lbs @ 1.650 & 231-245 lbs @ 1.220 lift
If these springs install at this rating, you will be fine.They will be fine even if installed slightly "taller", like at 1.700 "on the seat". How much valve lift is on your cam? DD |
| Author: | Doc [ Wed Mar 26, 2008 9:11 am ] |
Quote: Quote: 91-101 lbs @ 1.650 & 231-245 lbs @ 1.220 lift
If these springs install at this rating, you will be fine.They will be fine even if installed slightly "taller", like at 1.680 "on the seat". How much valve lift is on your cam? DD |
| Author: | the black sheep [ Fri Mar 28, 2008 12:10 am ] |
| Post subject: | Re: Springs |
HEY DD THE Cam i have just got in the mail today has 450" lift -the 15" lash so it`s 435" actual vavle lift .. its a camtech cam stage 3 .. http://www.camtechcams.com.au/cat/chrys.html the lumpier black sheep ... |
