It is currently Mon Nov 30, 2026 3:56 am
PostPosted: Mon Mar 31, 2008 7:56 am
Hi guys,
All of a sudden my temp and fuel gauges are too low.
The temp gauge gets to about 1/4" from the left and stays there even though the radiator seems at normal operating temperature. I haven't tested with a meat thermometer yet.
The fuel gauge indicates only about 3/4 full after filling the tank all the way. I'm pretty sure it drops towards zero as gas is consumed since after the previous fill-up it came down so fast I thought my tank had been siphoned. However, I haven't tested this yet.
About 2 months and 1000 miles ago I replaced a Taiwanese $15 electromechanical VR with a USA $60 electromechanical VR32 Echlin which solved an overcharging problem. The charging system still checks out OK.
So, what's the likely cause and what should I test next?
Zweistein
PostPosted: Mon Mar 31, 2008 8:37 am
Go to the Electrical section and look at a couple of current threads on guages. I believe you have lost ground or Your IVR is shot.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Amazon [Bot] and 1 guest
