It is currently Tue Jul 14, 2026 6:29 pm
 Post subject: How much to shave?
PostPosted: Tue Mar 11, 2008 9:39 pm
OK all you compression geniuses, I need your help. How much do I take off my head? I have 60cc combustion chambers, and a piston depth of .166. I want to have about 9:1 compression. I should be able to run regular with that I believe. So help me out, I would like to take the head in tomorrow afternoon to get cut. Thanks in advance for all your help.
Wylde Bill
63 Dodge 330
00 Sportster Rigid Bobber
05 Dodge Stratus (Wifes)
PostPosted: Tue Mar 11, 2008 10:48 pm
If you have a standard 3.400 bore and a .045 thick head gasket, your current compression is 7.71 to 1
Mill .100 and you will have 9.02 to 1, using a .045 head gasket.
 Post subject: Head at machine shop
PostPosted: Wed Mar 12, 2008 4:58 pm
I dropped the head off at the machine shop today. When I told him I wanted .10 off the head, he said you mean .050? I said no, .10. so he said he'll have to run it through a bunch of times as his machine does .010 at a time. I guess he's not used to slant 6's. I can get it back tomorrow afternoon, but since I have a meeting after work tomorrow, I'll probably have to pick it up on Friday. Oh well, I still have a bunch of cleaning to do before putting the motor back together.
Wylde Bill
63 Dodge 330
PostPosted: Wed Mar 12, 2008 9:04 pm
Users browsing this forum: Bing [Bot], volaredon and 12 guests
