| Hurst OD Shifter https://slantsix.org/forum/viewtopic.php?t=27818 |
| Author: | mlamb24 [ Thu Mar 13, 2008 11:58 am ] |
| Post subject: | Hurst OD Shifter |
Hello, I'm going to buy a hurst shifter for the 833 OD trans I have. Is it the same shifter used on non-OD transmissions? OR do I need a special part# for the OD shifter? Mine is an A body tailshaft. I need one with a reasonably short handle that curves back for a street rod project. Thanks in advance. Mike |
| Author: | Joshie225 [ Thu Mar 13, 2008 12:17 pm ] |
Same shifter. Buy your handle separately. |
| Author: | DusterIdiot [ Thu Mar 13, 2008 7:43 pm ] |
| Post subject: | Ditto... |
Quote: Same shifter. Buy your handle separately.
I would agree to that, if getting a junkyard shifter, any dodge/plymouth truck up to 1987 with the A-833 OD tranny will also have the shifter (but the lever and the linkage will be too long...)good luck, -D.Idiot |
| Author: | Jeffc [ Mon Mar 17, 2008 10:32 am ] |
I'm using a truck shifter handle in my A body, rev is a little close to the wheel, but works fine.... the standard 3-4 shift arm will not work from A unless you mod it...... OD applications have their own 3-4 arm. http://imageevent.com/jeffc/scampworks? ... =4&s=0&z=2 http://imageevent.com/jeffc/scampworks? ... =4&s=0&z=2 |
