It is currently Tue Jul 14, 2026 3:22 pm
 Post subject: CCing a head
PostPosted: Wed Mar 12, 2008 5:34 pm
Car Model: 63 Dart 81 D150
I think someone asked for pics of how to CC a head
The head.
I "paint" a thin layer of wheel bearing grease around the chamber to make it seal.
This is a cover form a CD case with 2 holes drilled in it the 1/4" hole is for
filling the chamber the smaller hole is to allow air to escape. The grease "glues" it to the head to prevent leaks.
I use a 60 CC (or ML) syringe from Tractor Supply (about $2.69 for a 2 pack) to fill the chamber.
This is just water with a few drops of green food coloring to mak it easier to see.
Fill the syringe with the water and try to get all the air bubbles out, get as exact as possible to the 60CC line. Try not to have this many air bubbles at the bottom.
Slowly inject the water in to the chamber.
The chamber filled with water
then just subtract what you have left in the syringe from the filled volume (60CC in this case) and that is your chamber volume. In the case of a larger chamber you may have to fill it up a second time and add the volume of 2 full syringes and subtract what is left. With a smaller syringe you just have to keep track of how many times you had to fill it.
Done carefully this will get you within a CC or two which is close enough for most of us. The more careful you are and the less air you have the more exact it is.
TopHat
PostPosted: Wed Mar 12, 2008 6:01 pm
I had problems acquiring a CC kit, I'm sure there is places to get them without being hassled. Instead though I was thinking about filling the head was play dough, and putting it in water to measure the water displaced. The Biology center get's rid of beakers every once in a while and you can get a good one if you search through them. Has anyone tried this before?
PostPosted: Wed Mar 12, 2008 6:29 pm
That's pretty much the procedure to figure out the volume of valve cutout notches in pistons.............
PostPosted: Wed Mar 12, 2008 6:50 pm
I had no problem at all getting the syringes at tractor supply today, no questions asked. They keep them right out on the shelf in the cattle health supply section.
TopHat
PostPosted: Wed Mar 12, 2008 7:12 pm
A 60cc catheter syringe is useless to a junkie....ask at your pharmacy.....if all else fails tell him the truth.
PostPosted: Wed Mar 12, 2008 7:19 pm
Yip, I got mine at the pharmacy as well (behind the counter). The other thing I did was cut a hole in some leftover lexan with a 5" hole saw. then add another hole for a breather. This rigid piece will never get cracked in the bottom of the tool box.
Sandy, I think you need to patent your design. (unless you stole it from someone else.)
PostPosted: Wed Mar 12, 2008 7:33 pm
I have a patent....it cost me $6500....
The CD cover was my own idea....but I think trying to collect royalties on it may be tough
PostPosted: Wed Mar 12, 2008 8:03 pm
Brass exhaust hangers? What's going on here?
You may just have to settle for recognition for the cd case idea.
PostPosted: Wed Mar 12, 2008 8:24 pm
http://www.arrowtipi.com/english/widgets.htm
PostPosted: Wed Mar 12, 2008 9:14 pm
Exhaust hangers, I was thinking it was some sort of male bondage accessary............. :twisted:
PostPosted: Wed Mar 12, 2008 9:22 pm
I was thinking it was some sort of ............. :twisted:
Your pushing the limit bucko! :shock:
Don't make me come over there and tie you to the roof of a Red Ale drinking TeePee builder's car for 3500 miles.
:lol:
PostPosted: Thu Mar 13, 2008 12:14 am
only a car guy would rig up a device outta exhaust clamps to go camp in a tipi... are you guys get a CC reading to get a better displacement idea?
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Thu Mar 13, 2008 5:55 am
Now I know I am late on this - yup internationally recognised way to do the cc job....umh when I saw the widget I winched....bondage hee heeee eeeouch... :twisted: :twisted:
Good idea though
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Mar 13, 2008 7:44 am
Poser
Tophat, thanks for the pics!! After the chambers are cc'ed and TDC and deck heighth are determined (as well as bore size), What is the formula for determining compresion ratio? Thanks,Wayne. :?
PostPosted: Thu Mar 13, 2008 8:16 am
I use the calculator found here:
http://www.csgnetwork.com/compcalc.html
TopHat
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 8 guests
