| new carb lots of smoke https://slantsix.org/forum/viewtopic.php?t=27829 |
| Author: | kenicb [ Thu Mar 13, 2008 7:55 pm ] |
| Post subject: | new carb lots of smoke |
the engine was running great when the original carb went out. replaced the carb with a rebuilt 1920 holly from Autozone. The first one I bought was no good. This is the second. Once I installed it, the engine idles ruff and lots of blue-ish smoke out of the tail pipe when accelerating. Is this the carb or another problem I should look for? thank so much Keni ish 6 8 |
| Author: | mopar_nocar [ Thu Mar 13, 2008 8:00 pm ] |
Have you checked your PCV valve? sb |
| Author: | SlantSixDan [ Thu Mar 13, 2008 8:26 pm ] |
Quote: a rebuilt 1920 holly from Autozone.
The problem is with "remanufactured" carburetors in general. They're junk. You'll keep swapping and swapping and likely never get one that works well. See this thread for more detailed information. Did you keep your original carb? |
| Author: | kenicb [ Fri Mar 21, 2008 1:57 pm ] |
| Post subject: | :new carb lots of smoke |
yes Dan i kept the old carb. the jet was not getting gas in |
