| Doc...Accurate way to measure pushrod length? https://slantsix.org/forum/viewtopic.php?t=2787 |
| Author: | DusterIdiot [ Sat Oct 20, 2001 7:22 pm ] |
| Post subject: | Doc...Accurate way to measure pushrod length? |
Well my slant rebuild is coming along nicely. Today I degreed the dang thing and got the head put back together. I ready to bolt everything back together. I've milled a total of .100 off the deck and head so I could raise compression. Is there an easy to order pushrod for this setup, or do you have a neat quick and easy trick to measure the proper length I'll need... thanks, -D.Idiot res0aus2@verizon.net |
| Author: | alienduster [ Sat Oct 20, 2001 10:19 pm ] |
| Post subject: | Re: Doc...Accurate way to measure pushrod length? |
: Well my slant rebuild is coming along nicely. : Today I degreed the dang thing and got the head : put back together. I ready to bolt : everything back together. : I've milled a total of .100 off the deck and : head : so I could raise compression. Is there an easy : to order pushrod for this setup, or do you : have a neat quick and easy trick to measure : the proper length I'll need... : : thanks, : : -D.Idiot DI - Comp and a few others sell adjustable pushrods available at you local speedshop. But the easy way is to cut a push rod (take out a 1/4" section), tap it for a stud on both sections, install said stud and use a locknut. I would guess you need a shorter pushrod to match the amount of milling, but using the adjustable let's you verify the geometry is correct. dlaray@earhtlink.net |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Oct 21, 2001 10:34 am ] |
: DI - Comp and a few others sell adjustable : pushrods available at you local speedshop. : But the easy way is to cut a push rod (take : out a 1/4" section), tap it for a stud : on both sections, install said stud and use : a locknut. I would guess you need a shorter : pushrod to match the amount of milling, but : using the adjustable let's you verify the : geometry is correct. That's what I have, a "home-made" adjusting pushrod. I have a couple of lock nuts on the one I have. I get everything set-up and use the "test pushrod" to find a good length. I lock it down and send it off to Smith Brothers and tell them to make 12-14 to the "sample length". ( I usually get a couple of extras - so make 14) A few days later I have a new set of "prefect length" pushrods and they return my test unit in the box. DD |
| Author: | Mel [ Mon Oct 29, 2001 5:08 pm ] |
Need the phone for Smith Bros. Quote:
: : That's what I have, a "home-made" : adjusting pushrod. I have a couple of lock : nuts on the one I have. I get everything : set-up and use the "test pushrod" : to find a good length. I lock it down and : send it off to Smith Brothers and tell them : to make 12-14 to the "sample : length". ( I usually get a couple of : extras - so make 14) : : A few days later I have a new set of : "prefect length" pushrods and they : return my test unit in the box. : DD usclstaffingnet@sprintmail.com |
