| bad hydrolic lifter https://slantsix.org/forum/viewtopic.php?t=27873 |
| Author: | USAJon [ Sun Mar 16, 2008 3:51 pm ] |
| Post subject: | bad hydrolic lifter |
our 1985 dodge ram 100 had old leaking cork valve cover gasket so when I put a new felpro valve cover gasket on, I notice I had non adjustable rocker arms. and that one was lose and clicking. also i notice 3 push rods were'ny oiling..any thoughts how to repair ? |
| Author: | slantzilla [ Sun Mar 16, 2008 4:06 pm ] |
Check the rockers, the lifters/pushrods oil from the top down. |
| Author: | USAJon [ Sun Mar 16, 2008 4:52 pm ] |
i'm thinking i have a slightly colisped lifter..and a few clogged pushrods..we have put 6K miles on it since the valve cover job... |
| Author: | dakight [ Sun Mar 16, 2008 5:00 pm ] |
The oiling path is though the rear rocker shaft standoff, the rocker shaft, rockers, the down through the pushrods. A clooged pushrod or rocker with prevent oil reaching the lifter. If the lifter doesn't get oil it will collapse. |
| Author: | LUCKY13 [ Sun Mar 16, 2008 6:19 pm ] |
I find the rockers stopped up most of the time this happens, a good cleaning and things return back to normal. Jess |
| Author: | slantfin [ Tue Mar 18, 2008 7:18 am ] |
| Post subject: | Same deal? |
I have this problem on my other, non-SLANT 6, A-body with the hyd. cam adj rocker 340 (1971). Does anyone know if this oils through the rocker arm similarly, or should I just go to 'wrongplacetoask.com' |
| Author: | slantzilla [ Tue Mar 18, 2008 7:23 am ] |
340 oils the rockers through the shaft. The pushrods are solid, no oil comes up through them. (or goes down) |
| Author: | slantfin [ Tue Mar 18, 2008 8:30 am ] |
Thanks, Slantzilla. I'll start with the rockers. |
| Author: | USAJon [ Tue Mar 25, 2008 9:19 pm ] |
Quote: I find the rockers stopped up most of the time this happens, a good cleaning and things return back to normal.
whats the pro way to remove the rocker shaft. I sure don't want to drop anything into the internals..
Jess |
| Author: | Joshie225 [ Tue Mar 25, 2008 9:27 pm ] |
You just described the Pro way. Don't drop anything! It's pretty easy really. Loosen each bolt a turn or so at a time until they are free. I get away with then lifting the whole assembly off the head with the bolts still resting in the shaft. Haven't lost anything down an engine yet. |
| Author: | USAJon [ Sun Apr 20, 2008 11:30 am ] |
well i took the rockarm assembly apart. some of the rear ones were carboned pretty bad..aprox 2.5 hour job to remove clean replace..oil change / still a tappin...looks like a bad lifter as when I check rocker arms and pushrod tubes they all flowed through their holes/ports. HOW do you take out the old lifters and replace with NEW ones without removing the head... A special tool ? just wondering...thanks |
| Author: | DusterIdiot [ Sun Apr 20, 2008 1:46 pm ] |
| Post subject: | Woof... |
Quote: HOW do you take out the old lifters and replace with NEW ones without removing the head...
on the 1975-1987 heads you have to remove the head, the holes aren't big enough to pull the lifters through like the earlier drool tube heads...-D.idiot |
