| Coil on Plug Conversion https://slantsix.org/forum/viewtopic.php?t=27901 |
Page 1 of 5 |
| Author: | nasstee pink dart [ Mon Mar 17, 2008 10:07 pm ] |
| Post subject: | Coil on Plug Conversion |
I was wondering if anyone has tried to convert the slant six to coil on plug? I have been considering it for my next project. |
| Author: | dank10fenny [ Mon Mar 17, 2008 10:15 pm ] |
distributorless igntion will still need a cam/crank sensor for the trigger... and an ecu to control it |
| Author: | Pierre [ Mon Mar 17, 2008 10:23 pm ] |
I put some passing thought into it. Right now I'm running Ford EDIS controlled by megasquirt. It would be trivial, electric wise to convert to COP. No major (electrical) re-engineering to do. May have to run dual modules to get more current on the primary side. Mounting the coils would be the trickiest part. This would be kind of cheating though, it would still function as wasted spark. I thought I read about some megasquirt firmware that could drive individual coils per cylinder. What ecu were you thinking about for COP? |
| Author: | Matt Cramer [ Tue Mar 18, 2008 6:17 pm ] |
It's something I plan to try next after my turbo upgrade. It shouldn't take nearly as long as the turbo has taken. |
| Author: | dank10fenny [ Tue Mar 18, 2008 6:34 pm ] |
is the ford edis waste spark? |
| Author: | Pierre [ Tue Mar 18, 2008 8:19 pm ] |
Yep it is. Easy way to tell - coil packs have one wire for the positive feed, and one negative wire per pair of coils. |
| Author: | dank10fenny [ Wed Mar 19, 2008 6:21 pm ] |
isnt that a way to determine the mated pairs as well...? |
| Author: | Pierre [ Wed Mar 19, 2008 6:36 pm ] |
Not sure what you mean by mated pairs. There are diagrams on the msns/msns-e sites of which plug towers equate to which pins on the harnes connector. |
| Author: | dank10fenny [ Wed Mar 19, 2008 11:16 pm ] |
im just speakin mated pairs on the cyls. like when two pistons are goin down at the same time regardless of which cycle they are on... |
| Author: | Matt Cramer [ Thu Mar 20, 2008 5:48 am ] |
They're 3 cylinders apart on the firing order. |
| Author: | emsvitil [ Thu Mar 20, 2008 1:13 pm ] |
1 5 3 6 2 4 1 & 6 5 & 2 3 & 4 You'll notice that the members of the pairs are split between the front 3 cylinders and the rear 3 cylinders and the symmetry of their locations |
| Author: | Sam Powell [ Sun Mar 23, 2008 6:21 am ] |
Good explanation Ems! Sam |
| Author: | Twisted Sixer [ Tue Apr 08, 2008 9:01 pm ] |
I know this is a silly ? but how deep are the spark plug tubes? Or another way of asking is how long would the coil need to be? This is a 3.2 chrysler coil
| Author: | dank10fenny [ Sun Apr 20, 2008 6:28 pm ] |
i would assume a little shorter than that. you gotta rember that those coil on plugs typicly go through the valve cover as well so they gotta be a bit longer... |
| Author: | Rug_Trucker [ Sun May 18, 2008 5:09 am ] |
What's the advantage of the coil on plug? |
| Page 1 of 5 | All times are UTC-07:00 |
