It is currently Sat May 30, 2026 5:28 pm
 Post subject: 14" disc brake wheels??
PostPosted: Mon Mar 17, 2008 5:53 pm
i am doing a disc brake conversion on my 74 valiant and obviously the fronts are now 5 x 4.5 for the bolt pattern. my question is will a 74 thru ? a-body or volare/aspen that came stock with disc brakes have 14" steel wheels with the 5 x 4.5 pattern?
 Post subject: Yes and no...
PostPosted: Mon Mar 17, 2008 6:02 pm
All A/F/M/J bodies after Jan 1976 came with mandatory disc brakes...so aspen/volares will have your wheels... when getting them off the 1973-1976 A-bodies they will have to be equipped with disc brakes for the 'large bolt pattern' (aka 5 lugs on 4.5")... if you need larger rims or a wider selection then the B/C bodies would also have 14-15" rims in the LBP depending on the options (which means if you get lucky and find a 1975 New Yorker with it's road rallyes on it they'll be 15x6" LBP rims...)
PostPosted: Tue Mar 18, 2008 7:01 pm
thank you that helps me a great deal.
