How to ID year of 8 3/4" rear end
https://slantsix.org/forum/viewtopic.php?t=27916
Author:  wjajr [ Tue Mar 18, 2008 8:46 pm ]
Post subject:  How to ID year of 8 3/4" rear end
Please view my post under brakes for more titilating questions.
Tonight I jacked the old Crate up to pull the rear drums, and figured I would check the rear end ratio using one wheel in the air, and count the revolutions of the U joint method. Apparently I have a limmited slip or no-slip, cause that wheel wouldn't turn with the transmission in N. Would the ratio be stamped on the differential assembly somewhere. It is a bit cruddy under her, if I knew where to scrape & rub it would help.
Author:  Jeffc [ Mon Mar 24, 2008 9:17 am ]
Very rare to see it stamped from the factory, most often if it
has not been taken apart it will be on a tag attached to one
of the pumkin bolts....
