| Mounting Degree Wheel https://slantsix.org/forum/viewtopic.php?t=2792 |
| Author: | Brent [ Sun Oct 21, 2001 9:36 pm ] |
| Post subject: | Mounting Degree Wheel |
What is the best way of mounting a 7" Mr. Gasket degree wheel on a Slant 6 and any comments on competition cams 264 camshaft would be appreciated. Thank you. lauchlin@shaw.ca |
| Author: | CrAlt [ Mon Oct 22, 2001 8:15 am ] |
| Post subject: | Re: Mounting Degree Wheel *PIC* |
: What is the best way of mounting a 7" Mr. : Gasket degree wheel on a Slant 6 and any : comments on competition cams 264 camshaft : would be appreciated. Thank you. See <A HREF="http://hackme.dhs.org">http://hackme.dhs.org</A>:8080/pics/degree/ I took pics of mine mounted. from the side cralt@hackme.dhs.org |
| Author: | DusterIdiot [ Mon Oct 22, 2001 12:46 pm ] |
| Post subject: | Re: Mounting Degree Wheel |
That is the best way to do it. Although you could get away with drilling the center and using a crank bolt with a rubber washer. The 3 bolt method is the best. I degreed in my Comp Cams 252S Saturday, and found that the Cloyes Double Roller chain and sprockets I purchased from NAPA had mismarked "dots" stamped on them. After the initial degreeing I had to run over to my friends and drill press my cam gear and use the Mopar Bushing set I got (used the 4 degree bushing) to get it within spec. -D.Idiot res0aus2@verizon.net |
| Author: | Charlie Schmid [ Mon Oct 22, 2001 8:22 pm ] |
D.I. Do you have a part number for the NAPA/Cloyes chain and sprocket set? Charlie Quote:
: : That is the best way to do it. Although you : could get away with drilling the center and : using a crank bolt with a rubber washer. The : 3 bolt method is the best. : I degreed in my Comp Cams 252S Saturday, and : found that the Cloyes Double Roller chain : and sprockets I purchased from NAPA had : mismarked "dots" stamped on them. : After the initial degreeing I had to run : over to my friends and drill press my cam : gear and use the Mopar Bushing set I got : (used the 4 degree bushing) to get it within : spec. : : -D.Idiot flturbo6@aol.com |
