| Squeaky front suspension? https://slantsix.org/forum/viewtopic.php?t=27936 |
| Author: | polkat [ Thu Mar 20, 2008 12:49 am ] |
| Post subject: | Squeaky front suspension? |
The rubber bushings (A arm, etc.) in the right front of my '73 Dart, which were installed maybe half a year ago, look to be in good shape. But they squeak a lot! Just pressing slightly down on the fender will cause the squeak! Is there anything (rubber safe) that I can spray on them to quiet them up a bit? Or could it be ball joints? The strut bushings are good. Thanks! ________ buy easy vape vaporizer |
| Author: | dakight [ Thu Mar 20, 2008 5:37 am ] |
Were they replaced with rubber or polyurethane bushings? Poly is notorious for squeaking, rubber not so much. When I worked in the tire business we used a rubber lube called Ruglyde and just squirted it on the bushings but it never lasted long. As soon as the lubricant dried out again the squeak would often come back. |
| Author: | vynn3 [ Thu Mar 20, 2008 6:52 am ] |
If, during installation, the lower control arm pivot nuts weren't torqued to spec with the car on the ground, they could be binding, and may even need to be replaced again. |
| Author: | polkat [ Thu Mar 20, 2008 10:37 am ] |
They are rubber. The nuts are tight, but I don't know if they are torqued to spec. Anyone know the torque value? Thanks! ________ vaporizers |
