| bbp brain fart https://slantsix.org/forum/viewtopic.php?t=27956 |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:00 pm ] |
| Post subject: | bbp brain fart |
5-4.5" is the chrysler BBP right? im bout to order rims and im makin sure im gettin it right. im goin for the 14x7 outlaw II's wit the 5-4.5 BC this is a 72 valiant that has been upgraded to discs and BBP i also want to make sure my tires i have will work on here. the tires i had were stock on my small bolt pattern. i should be able to get this myself, but then again i want to be sure is 14x7 typicly stock? |
| Author: | stuggin [ Thu Mar 20, 2008 7:01 pm ] |
yep, 5x4.5. |
| Author: | emsvitil [ Thu Mar 20, 2008 7:02 pm ] |
What backspacing are you getting? |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:02 pm ] |
i just edited on the size cuz my tires say 195 r 14 |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:04 pm ] |
my ol moderns that looked like outlaws had no spacer the outlaws say they have zero offset |
| Author: | emsvitil [ Thu Mar 20, 2008 7:04 pm ] |
7" is a little wide for a 195 tire Also 195 75 or 195 70? |
| Author: | emsvitil [ Thu Mar 20, 2008 7:07 pm ] |
0 offset on a 7" rim is 4" backspacing Don't know if that will clear the tie-rods with a 14" (it will with a 15"), and definitely won't with a 13" |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:07 pm ] |
tires are 195-75-r14 that i would use |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:09 pm ] |
the rims that were on it were fine.... dont know the backspaing on moderns though. i was using the same tire |
| Author: | emsvitil [ Thu Mar 20, 2008 7:15 pm ] |
14" stock rims were 4.5 5.5 or 6.0 wide. |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:20 pm ] |
alright, sittin here wit tape measure on old rim that worked. top to bottom bout 15" so thats a 14" bead goin for width - outer edge to outer edge is 7" inside edge to inside is about 6" shoulda paid more attention in suspension classs ha! |
| Author: | emsvitil [ Thu Mar 20, 2008 7:33 pm ] |
So you need 14x6 with 0 offset you'd get 3.5" backspacing which is perfect........ |
| Author: | dank10fenny [ Thu Mar 20, 2008 7:43 pm ] |
cool, thanks for the tire lesson on my buddies rice rocket hes got 205's on a 9" rim. fricken pyramid tires, ha edit: the 14x6 wheels got +6mm offset and backspacing of 3-3/4 |
