It is currently Thu Dec 25, 2025 5:56 am
 Post subject: bbp brain fart
PostPosted: Thu Mar 20, 2008 7:00 pm
5-4.5" is the chrysler BBP right? im bout to order rims and im makin sure im gettin it right.
im goin for the 14x7 outlaw II's wit the 5-4.5 BC
this is a 72 valiant that has been upgraded to discs and BBP
i also want to make sure my tires i have will work on here. the tires i had were stock on my small bolt pattern. i should be able to get this myself, but then again i want to be sure is 14x7 typicly stock?
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Thu Mar 20, 2008 7:01 pm
yep, 5x4.5.
1962 Valiant V-200
170 C.I. Super Six, HEI, Dutra Duals
PostPosted: Thu Mar 20, 2008 7:02 pm
What backspacing are you getting?
i just edited on the size cuz my tires say 195 r 14
PostPosted: Thu Mar 20, 2008 7:04 pm
my ol moderns that looked like outlaws had no spacer
the outlaws say they have zero offset
7" is a little wide for a 195 tire
Also 195 75 or 195 70?
PostPosted: Thu Mar 20, 2008 7:07 pm
0 offset on a 7" rim is 4" backspacing
Don't know if that will clear the tie-rods with a 14" (it will with a 15"), and definitely won't with a 13"
tires are 195-75-r14 that i would use
PostPosted: Thu Mar 20, 2008 7:09 pm
the rims that were on it were fine.... dont know the backspaing on moderns though. i was using the same tire
PostPosted: Thu Mar 20, 2008 7:15 pm
14" stock rims were 4.5 5.5 or 6.0 wide.
PostPosted: Thu Mar 20, 2008 7:20 pm
alright, sittin here wit tape measure on old rim that worked.
top to bottom bout 15" so thats a 14" bead
goin for width - outer edge to outer edge is 7" inside edge to inside is about 6"
shoulda paid more attention in suspension classs ha!
PostPosted: Thu Mar 20, 2008 7:33 pm
So you need 14x6
with 0 offset you'd get 3.5" backspacing which is perfect........
PostPosted: Thu Mar 20, 2008 7:43 pm
cool, thanks for the tire lesson
on my buddies rice rocket hes got 205's on a 9" rim. fricken pyramid tires, ha
edit: the 14x6 wheels got +6mm offset and backspacing of 3-3/4
