It is currently Sat May 23, 2026 7:46 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: rpm
PostPosted: Sun Oct 28, 2001 9:56 am
Does anyone know what RPM range a slant 6 with a competition cam 260H-10 camshaft? (super six 2 barrell, nine and one-half to one compression, crane HI-6 ignition and crane coil, stock exhaust) It is turning 2000 rpm at 50 mph right now. Is this too low?
lauchlin@shaw.ca
 Post subject: Re: rpm
PostPosted: Sun Oct 28, 2001 1:59 pm
: Does anyone know what RPM range a slant 6 with
: a competition cam 260H-10 camshaft? (super
: six 2 barrell, nine and one-half to one
: compression, crane HI-6 ignition and crane
: coil, stock exhaust) It is turning 2000 rpm
: at 50 mph right now. Is this too low?
I would think you need to get a lot lower rear end gears, as you are just begining to get into the starting of the power band. I have a 3320lb car and I use 3.50 for street and 4.11 for drags.
dbjerklund@hotmail.com
PostPosted: Sun Oct 28, 2001 2:55 pm
: I would think you need to get a lot lower rear
: end gears, as you are just begining to get
: into the starting of the power band. I have
: a 3320lb car and I use 3.50 for street and
: 4.11 for drags.
this is in my van 3700 lb brent
lauchlin@shaw.ca
