It is currently Mon May 18, 2026 6:21 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Oct 09, 2001 6:03 am
Anyone know where I can get new, NOS, or even very good used weatherstriping for the doors on a 4 dr sedan 68 Valient? The existing is NG, and we have the car all repainted satin black, and just need the door and trunk rubbers to finish. Steele's only shows 2 dr and conv rubber. They also show a general trunk rubber for all Chryslers in this year range that appears correct. The door rubbers are the same profile all the way around the door, and fit into a small channel on the top and partway down the sides. Need about 13 feet for the front doors and 11-12 feet on the back (per door).
Thanks
Smith
sgw041454@aol.com
PostPosted: Sun Oct 21, 2001 9:44 am
: Anyone know where I can get new, NOS, or even
: very good used weatherstriping for the doors
: on a 4 dr sedan 68 Valient?
: Thanks
: Smith
Got mine for my 63 Valiant off of a 97(?)Cadillac Catera at the bone yard. They fit great on the front, a little tight on the rear doors.
Dan
reptylkrib@aol.com
PostPosted: Mon Oct 29, 2001 10:50 am
: on a 4 dr sedan 68 Valient? The existing is
: NG, and we have the car all repainted satin
: black, and just need the door and trunk
: rubbers to finish. Steele's only shows 2 dr
: and conv rubber. They also show a general
: trunk rubber for all Chryslers in this year
: range that appears correct. The door rubbers
: are the same profile all the way around the
: door, and fit into a small channel on the
: top and partway down the sides. Need about
: 13 feet for the front doors and 11-12 feet
: on the back (per door).
: Thanks
: Smith
Check out <A HREF="http://www.garygoers.com/">http://www.garygoers.com/</A> and see if you can find something there. You will probably need to contact him or get a full catalog. I didn't see weatherstrip there but my dad bought some for his '65 4-door Dart years ago. It is pretty good but fit a bit tight when closing the doors.
Chuck
Chuck
webmaster@omnipages.com
