It is currently Mon Nov 30, 2026 12:33 am
PostPosted: Tue Mar 25, 2008 9:53 am
FX-1 Timing computer (G-Tech) is showing on the last run a few days ago a 14.50 at 91.9MPH and a 1.98 60'. I had a little stumble on the line, running the full exhaust (not uncapped), and could have shifted/split shifted a little better.
The log showed a little on the rich side (12.3). Do you think leaving the AFR set at this level would lean out a bit with the exhaust uncapped?
I wish the track was open today. The air is perfect. I guess I'll bring the power inverter to run the laptop (bad battery) so I can check the logs between runs.
PostPosted: Tue Mar 25, 2008 11:48 am
I wouldn't think uncapping would raise AF too much given your exh design, but anything is possible. You should be safe (insert disclaimer :wink: ). Good news on the Gtech run and let's see some whompin' timeslips...
If you're worried about detonation, just retard timing 2-3 deg on the uncapped run and check AF, then advance again if safe.
Users browsing this forum: Amazon [Bot] and 1 guest
