Goofy choke question.
https://slantsix.org/forum/viewtopic.php?t=28060
Author:  cudaspaz [ Tue Mar 25, 2008 5:50 pm ]
Post subject:  Goofy choke question.
Could a manually operated cable type choke be used to eliminate the electric and non electric type chokes on these /six motors?
Author:  DusterIdiot [ Tue Mar 25, 2008 5:56 pm ]
Post subject:  Yes...
Some of the 60's truck used that kind of arrangement, if you can get a choke cable (or a lawn mower throttle cable), and 'engineer' the brackets to hold the cable under the dash, and to the carb, it should be ok... the real trick is making sure:
1) you don't unload the choke too soon during cold starts as it can die out
2) don't forget to unload the choke or it'll run rich and you'll lose some power and have the 'black smoke' following you around town...
-d.Idiot[/quote]
Author:  sandy in BC [ Tue Mar 25, 2008 7:10 pm ]
The real way to get rid of the choke is EFI......
Author:  dank10fenny [ Tue Mar 25, 2008 9:30 pm ]
i love my manual choke, only usin it when i really need it, like cold starts and cold morinin big hill accel. i can adjust the high/low idle too
Author:  KBB_of_TMC [ Wed Mar 26, 2008 9:51 am ]
Over the years, I did a number of manual choke conversions. It used to be easy to find universal kits to do it. The only trick I'd recommend is to heavily grease the cable about 1/year, as they were prone to sticking. For some reason, my Holley aftermarket 2bbl designed for a manual choke requires much more travel than any of the carbs designed for automatic choke.
The new electric chokes I've had work well enough that I now use them rather than the manual.
Author:  bringtheboom [ Wed Mar 26, 2008 11:54 am ]
my 73 valiant has a "custom" manual choke. works o.k. but it is a little stiff. and took some precision welding of bracketry to the carb. but the price was right.
Author:  cudaspaz [ Wed Mar 26, 2008 12:50 pm ]
Cool, does anyone have pics of their manual set up at the carb?
I've seen some nice looking hemi type manual choke cables on ebay that were all stainless inside and out.
