crank bolt
https://slantsix.org/forum/viewtopic.php?t=28090
Author:  notmy6 [ Thu Mar 27, 2008 3:00 pm ]
Post subject:  crank bolt
does the 225 use a crank bolt for the front pulley? I had to replace the balancer and there was no bolt in the crank. just wondering if these motors take a bolt or not?
Thanks Again
Mike
Author:  Joshie225 [ Thu Mar 27, 2008 3:28 pm ]
Most don't have a damper from the factory, but the small block bolt fits just fine.
Author:  DusterIdiot [ Thu Mar 27, 2008 3:29 pm ]
Post subject:  Yes...
The balancer was press fit at the factory, and most engines didn't get one, but the crank nose is threaded for a bolt... it's 3/4 NF about 1 1/4" long stock ones are grade 8... you can pick one out of a junkyard they are the same as the small block/big block damper bolts (find a 318 and bring an 1 1/4" wrench or breaker bar along...)
