guage swap
https://slantsix.org/forum/viewtopic.php?t=28112
Page 1 of 1
Author:  lincparts [ Sat Mar 29, 2008 9:42 am ]
Post subject:  guage swap
i swaped out the ammeter for a voltmeter(63). I transplanted the circuit board from my guage cluster to the cut up new cluster. I put it all back together and nothing. I went back and read posts and cleaned up the copper contacts (with an eraser) reinstalled and now the guages would peg to the right. Both gas and temp, but if i unhook the temp wire from the sender , then only the gas guage wants to peg. Now does this mean that another open ground is still stopping me. what causes this?
Author:  Chuck [ Fri Apr 11, 2008 6:20 pm ]
It sounds like the instrument regulator is putting out too much voltage. It should be pulsing about 5-6 volts. On the 63 the regulator is inside the fuel gauge, which is a pain to fix. You need to put a voltmeter on the middle of the three terminals of the fuel gauge to see what the output voltage is.
