It is currently Wed Nov 25, 2026 9:06 pm
 Post subject: Retorque head gasket?
PostPosted: Tue Apr 01, 2008 2:12 pm
I repalced my oil pan and head gasket a couple a week or so ago. I have taken it on a couple of nice cruises since. Should I retorque the head despite the Felpro gasket says no retorque.
If I do, should the engine be hot, warm, cold?
Loosen bolts first, or just tighten to 70-75 and see if it is loose?
PostPosted: Tue Apr 01, 2008 4:40 pm
I always retorque a head gasket after the first few heat cycles.
Do the check with the engine warm, basically as it is cooling after being hot.
Just go more on the tightening, I never loosen and retighten but know that others have done it that way.
PostPosted: Tue Apr 01, 2008 4:57 pm
Thanks Doc, so far it looks like my oil leak problems are fixed.
Users browsing this forum: Bing [Bot] and 13 guests
