| Retorque head gasket? https://slantsix.org/forum/viewtopic.php?t=28164 |
| Author: | RDJ [ Tue Apr 01, 2008 2:12 pm ] |
| Post subject: | Retorque head gasket? |
I repalced my oil pan and head gasket a couple a week or so ago. I have taken it on a couple of nice cruises since. Should I retorque the head despite the Felpro gasket says no retorque. If I do, should the engine be hot, warm, cold? Loosen bolts first, or just tighten to 70-75 and see if it is loose? |
| Author: | Doc [ Tue Apr 01, 2008 4:40 pm ] |
I always retorque a head gasket after the first few heat cycles. Do the check with the engine warm, basically as it is cooling after being hot. Just go more on the tightening, I never loosen and retighten but know that others have done it that way. DD |
| Author: | RDJ [ Tue Apr 01, 2008 4:57 pm ] |
Thanks Doc, so far it looks like my oil leak problems are fixed. |
