| How to put in a Brake Light Switch https://slantsix.org/forum/viewtopic.php?t=28193 |
| Author: | 75plyduster [ Wed Apr 02, 2008 5:36 pm ] |
| Post subject: | How to put in a Brake Light Switch |
Its for a 1975 Plymouth Duster. Its not the screw in kind. I cant figure out to put it in. Help would be appreciated. |
| Author: | DusterIdiot [ Wed Apr 02, 2008 7:07 pm ] |
| Post subject: | Time to get the flash light... |
Grab your flashlight and a magic marker.... Sit in your front seat like you're blasting off (aka head on the floorboard, legs draped over the top of the seat...) Follow the brake pedal lever up to the pedal assembly, and you'll see a crossmember... look for the switch it's in a bracket that about 3 more inches toward the dash board will have a bolt (3/8" or 7/16" socket needed)... find the end of the bracket and trace around it with the marker... unhook your brake light wire, unbolt bracket, swap out the switch... re bolt in using marker line as a rough esitmate... plug in wire... test and check the tail lights (using a buddy to watch, a mirror, inside the garage with the lights out...) Good Luck -D.Idiot |
| Author: | 75plyduster [ Thu Apr 03, 2008 10:40 am ] |
I took out the bracket and I dont know how to put the switch into it. |
| Author: | 75plyduster [ Thu Apr 03, 2008 11:38 am ] |
Thanks for your help I figured it out. |
