It is currently Wed Nov 25, 2026 10:22 am
 Post subject: Fuel sender
PostPosted: Fri Apr 04, 2008 4:08 am
Hi There
I am bussy cleaning up the underside of the 68 fb cuda - removing underseal, treating surface rust, ruberising etc.
Removed my fuel tank for some beauty treatment - and to reach the bits hidden behind the tank - my fuel sender was much worse for wear - 40 years will do that to a mechanism.
The contact on the reostat was gone, the float was coroded through - I think some galvanic reaction ate the float - the tank is fully galvinised!! - think sme water in the tank the brass float, and the zinc coating ate it up!!
What to do - a new SS unit costs 127usd, a ms one 70 odd and with the current exchange rate...... Locally between 750 and a 1000 rand
Walked into the local autoquip - saw they had a generic VDO made sender
To make a long story short - I removed my sender unit from the tank flange mounted theirs - I replace the rheostat - and it works like a charm
Looks stock and it works - will post pics
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
Users browsing this forum: Bing [Bot] and 9 guests
