| Fuel sender https://slantsix.org/forum/viewtopic.php?t=28214 |
| Author: | 68barracuda [ Fri Apr 04, 2008 4:08 am ] |
| Post subject: | Fuel sender |
Hi There I am bussy cleaning up the underside of the 68 fb cuda - removing underseal, treating surface rust, ruberising etc. Removed my fuel tank for some beauty treatment - and to reach the bits hidden behind the tank - my fuel sender was much worse for wear - 40 years will do that to a mechanism. The contact on the reostat was gone, the float was coroded through - I think some galvanic reaction ate the float - the tank is fully galvinised!! - think sme water in the tank the brass float, and the zinc coating ate it up!! What to do - a new SS unit costs 127usd, a ms one 70 odd and with the current exchange rate...... Locally between 750 and a 1000 rand Walked into the local autoquip - saw they had a generic VDO made sender To make a long story short - I removed my sender unit from the tank flange mounted theirs - I replace the rheostat - and it works like a charm Looks stock and it works - will post pics |
