| Alternator bracket on Decked block https://slantsix.org/forum/viewtopic.php?t=28251 |
| Author: | ceej [ Sun Apr 06, 2008 4:26 pm ] |
| Post subject: | Alternator bracket on Decked block |
The alternator bracket was a bit cock-eyed sitting on it's mounting pads after serious decking of the block. Fopar stopped by and recommended slotting the bolt hole that goes to the head. I clamped it down on my mill and cut the slot to allow the bracket to sit flush on the block and the head. It's all those little things. I just finished grinding down the pads on the manifold side of the block to clearance for the Dual Dutra Duals. When I put the DDD's up to the head, they interfered with the pads. A similar issue with headers as Fopar tells me. I've got a long way to go! My hands are still tingling from all the grinding, and my nose is full of Iron dust! CJ |
| Author: | DusterIdiot [ Sun Apr 06, 2008 9:12 pm ] |
| Post subject: | Yep... |
Quote: I just finished grinding down the pads on the manifold side of the block to clearance for the Dual Dutra Duals.
When I put the DDD's up to the head, they interfered with the pads. That happened when I mocked up the split manifold version, it's the late block with that pad under the block deck that does it... Quote: The alternator bracket was a bit cock-eyed sitting on it's mounting pads after serious decking of the block.
You might have not had to do that if you used a later model sheet metal bracket off a 1979+ F/M/J body or a 1979-1987 Truck... (they only bolt to the block, not the head....)FYI, -D.Idiot |
| Author: | sandy in BC [ Mon Apr 07, 2008 6:48 am ] |
Quote: You might have not had to do that if you used a later model sheet metal bracket off a 1979+ F/M/J body or a 1979-1987 Truck... (they only bolt to the block, not the head....)
Thanks for the very good fix for this DI!
| Author: | SlantSixDan [ Mon Apr 07, 2008 7:14 am ] |
The '79+ bracket also spaces the alternator's bottom ears further away from the block, which facilitates the use of an '89+ Nippondenso, Bosch, or Chrysler 40/90 or 50/120 alternator, which is not only more efficient and powerful, but also considerably smaller and lighter if you choose the Nippondenso version. Then there's the AREngineering solution. |
| Author: | Pierre [ Mon Apr 07, 2008 8:22 am ] |
FYI - several months, maybe a year ago I asked AndyF about the AREngineering kit and it had been discontinued. |
| Author: | DusterIdiot [ Mon Apr 07, 2008 9:58 am ] |
| Post subject: | If you have to go the other way... |
I also notice on the early 60's trucks/vans(industrial/farming engines) they have the driver's side alternator mounting brackets, that also may be a quickie junkyard item, but you can't have power steering to use it effectively... -D.Idiot |
| Author: | SlantSixDan [ Mon Apr 07, 2008 10:20 am ] |
| Post subject: | Re: If you have to go the other way... |
Quote: I also notice on the early 60's trucks/vans(industrial/farming engines) they have the driver's side alternator mounting brackets
Definitely on the A100/A108 vans with slant-6 engines. I think most (all?) of the D/W pickups had the distributor-side alternator setup like '61+ passenger cars. Not sure where the alternator is in a B-series van with slant-6, but I think it's on the distributor side. Quote: but you can't have power steering to use it effectively
There were a lot of special parts used to have P/S in a '60 Valiant. The alternator's "bottom" bracket was cast integrally with the special thermostat housing, a slider bracket came up from the P/S pump support, etc. I wonder what was done on A-vans with slant-6 and P/S. For that matter, I wonder if P/S was available on A-vans.
| Author: | 6shotvanner [ Mon Apr 07, 2008 1:31 pm ] |
FYI,no pwr steering on A vans/pkup according to my FSM.Also B vans indeed the alt sits on dist side.Happy parts hunting |
| Author: | Greg Ondayko [ Mon Apr 07, 2008 2:15 pm ] |
On my dart i kept the Cast iron alternator mount and I have both the block and head with .100" off of them. so I just shimmed it up with washers! On a quasi related topic, SSDan, I have a small alternaor that I grabbed off a 90's Dodge truck - how do I ID it as to which one it is?? (Nippondenso, Bosch, or Chrysler 40/90 or 50/120) and how do I wire it to my volare -- I have the Sheet metal Bracket there! I plan to install it to run the EFI I will be puttin on there this summer! Thanks A link will work if you dont want to hijack this thread. Greg |
