| 904 Auto to OD833 manual conversion Is SL6 crank the same? https://slantsix.org/forum/viewtopic.php?t=28265 |
| Author: | Scott H [ Mon Apr 07, 2008 1:20 pm ] |
| Post subject: | 904 Auto to OD833 manual conversion Is SL6 crank the same? |
I bought a 77 Aspen donor car with sl6 and 833 OD trans to go into an 80 Volare with sl6 and automatic. In doing my research I discovered that when doing a auto to std conversion on a V8 the cranks that came with autos were not machined to accept the input shaft bushing/bearing. Is this an issue on the slant six cranks? Thanks, Scott |
| Author: | terrylittlejohn [ Mon Apr 07, 2008 3:31 pm ] |
all the slantsix`s i have come accross are machined for the pilot bushing, i used all the parts of a 76 aspen to go in my 75 duster no problems |
| Author: | DusterIdiot [ Mon Apr 07, 2008 5:39 pm ] |
| Post subject: | Nope... |
Quote: all the slantsix`s i have come accross are machined for the pilot bushing
It's more hit and miss for the late cast cranks... My '79 block was not and I had to use the NAPA problem solver bushing with some loctite for it... so far all the forged cranks I have (pre-76ish) have either been drilled or already had the bushing in it... -D.Idiot |
| Author: | terrylittlejohn [ Tue Apr 08, 2008 11:30 am ] |
D idiot, what type of bushing was the napa one ,and how does it work |
| Author: | slantzilla [ Tue Apr 08, 2008 12:42 pm ] |
You can also use a roller pilot bushing from a V-6 or V-8 Dakota. It will drive into the crank register for the converter. |
| Author: | DusterIdiot [ Tue Apr 08, 2008 1:27 pm ] |
| Post subject: | Your two choices... |
Quote: D idiot, what type of bushing was the napa one ,and how does it work
Balkamp 615-1033 is a stockish style oilite pilot bushing with and undersized outer diameter... for those cranks that have the hole but it's not finished/drilled to the correct diameter... you coat the bushing with HD loctite and insert into the crank, leave until the loctite settles (about 20 minutes+), then insert a small amount of grease per SOP and install your clutch...Option two is a bit better, as big D has said order mopar part number: 53009180AB for a Dakota V-6 or V-8 is takes up the pocket in the crank... good luck, -D.idiot |
| Author: | 65s [ Wed Jun 11, 2008 10:19 pm ] |
Will I need this Dakota bushing to mate an auto /6 to my 3-on-the-tree tranny? It's a 1965 tranny and a 1972 /6. |
| Author: | DusterIdiot [ Thu Jun 12, 2008 5:41 am ] |
| Post subject: | Maybe |
Quote: Will I need this Dakota bushing to mate an auto /6 to my 3-on-the-tree tranny? It's a 1965 tranny and a 1972 /6.
You might, check the back of the crank and see if it has a finished hole or a bushing in it already... -D.Idiot |
| Author: | 65s [ Thu Nov 06, 2008 9:44 pm ] |
Turns out the '65 motor had a bushing which we were able to remove with a puller and put into the '72 motor. The end of the crank on the '72 motor was bigger, so I had to have the center hole of the flywheel machined larger....then all was well and the motor went in. thanks! |
