gm hei with msd 6a?
https://slantsix.org/forum/viewtopic.php?t=28286
Author:  dclxvi [ Tue Apr 08, 2008 2:15 pm ]
Post subject:  gm hei with msd 6a?
can u wire up the gm hei and still run my msd 6a or is that overkill. if its too much which would be the better choice
Author:  Charrlie_S [ Tue Apr 08, 2008 3:15 pm ]
Post subject:  Re: gm hei with msd 6a?
You use one or the other, not both. Unless you have a "race" car, you don'r need to spen the money for a MSD 6.
The HEI is more bang for the buck, and will supply all you need on a stock or modified street car. I have the HEI on my "low buck" race car.
Author:  polkat [ Tue Apr 08, 2008 3:17 pm ]
Although I am a supporter of the HEI swap, I'd say that if you already have the MSD and it works okay, use that.
________
Ford Futura picture
Author:  Joshie225 [ Tue Apr 08, 2008 3:54 pm ]
You can have the HEI trigger the MSD if you really want. The only benefit to that is if the MSD fails you can switch back to the HEI easier. Personally I'd set up the MSD to trigger directly from the distributor and put the HEI parts in the glove or tool box.
