It is currently Sun May 17, 2026 4:00 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: DD??
PostPosted: Fri Nov 02, 2001 11:59 am
Hey Doug, would you assume the buick valves would be ok for a camshalf with aprox. .460-.467 lift? Is it possible to change anything by a few thousandths to get it closer in spec with a stock /6 valve lenth? Thanx
Do0dlebug19@aol.com
PostPosted: Fri Nov 02, 2001 12:38 pm
: Hey Doug, would you assume the buick valves
: would be ok for a camshalf with aprox.
: .460-.467 lift? Is it possible to change
: anything by a few thousandths to get it
: closer in spec with a stock /6 valve lenth?
A number of SL6 Racers use the Buick valves with lifts beond .470 and they work fine. The key is to have all the correct springs, retainers and locks (keepers) which go with the valve. The spring's Installed Height must be checked (seat pressure) Also be sure the guides are sized correctly seeing that different valves can have different stem diameters for oil clearance.
To correct for the shorter Buick valve length, all you can do is mill the head. (this helps give back some pushrod adjuster turns)
The other thing I have seen done is to "sink" the valve seat into the head deeper. This is NOT a good thing to do because it reduces flow.
Let's face it, you have more to work with if the valve is a little longer, not shorter.
PostPosted: Fri Nov 02, 2001 9:46 pm
: A number of SL6 Racers use the Buick valves
: with lifts beond .470 and they work fine.
: The key is to have all the correct springs,
: retainers and locks (keepers) which go with
: the valve. The spring's Installed Height
: must be checked (seat pressure) Also be sure
: the guides are sized correctly seeing that
: different valves can have different stem
: diameters for oil clearance.
: To correct for the shorter Buick valve length,
: all you can do is mill the head. (this helps
: give back some pushrod adjuster turns)
: The other thing I have seen done is to
: "sink" the valve seat into the
: head deeper. This is NOT a good thing to do
: because it reduces flow.
: Let's face it, you have more to work with if
: the valve is a little longer, not shorter.
: DD
Hey Doug, I was planning on milling the head .070,sounds like In your perspective, I will be ok.I think the valve size is about where I would like it.My machinist doesnt think going really big on the intake side is smart, and I kinda agree. Exhaust is usually where the hp gains are. Dealing with a whole different engine now, you tell me whats more important,intake or exh.? Thanx a Million
Do0dlebug19@aol.com
PostPosted: Sat Nov 03, 2001 9:03 am
: Hey Doug, I was planning on milling the head
: .070,sounds like In your perspective, I will
: be ok.I think the valve size is about where
: I would like it.My machinist doesnt think
: going really big on the intake side is
: smart, and I kinda agree. Exhaust is usually
: where the hp gains are. Dealing with a whole
: different engine now, you tell me whats more
: important,intake or exh.? Thanx a Million
You are in a good size range and yes, the exhaust side tends to need a little more effort, both side benifit for all the porting work you can give them, think "line of sight" or trying to take some of the bend out of the port as well as grinding-out all the restrictions.
PostPosted: Sun Nov 04, 2001 7:06 am
Hello All,
Even though milling the head would allow the pushrod to reach, the rocker geometry may be affected by the shorter valves, no? Maybe lash caps could be used to make the buick valves the same heigth as stock? I've seen lash caps in .060" and .080"
Dave
<snip
: DD
dbrode@hereintown.net
PostPosted: Sun Nov 04, 2001 2:28 pm
: Hello All,
: Even though milling the head would allow the
: pushrod to reach, the rocker geometry may be
: affected by the shorter valves, no? Maybe
: lash caps could be used to make the buick
: valves the same heigth as stock? I've seen
: lash caps in .060" and .080"
: Dave
: <snip
ARE LASH CAPS SAFE? HOW MUCH MORE EXSPENSIVE IS IT? wHAT EXACTLY WOULD HAPPEN IF THE VALVE IS SHORTER, LOSS OF RPM? LOSS OF TQ? LOSS OF HP? pOSSIBLY BETTER, WHO KNOWS? tHANX
PostPosted: Sun Nov 04, 2001 2:41 pm
Lash caps are commonly used with valves that have no hard tip. They aren't real pricey. They also
give more area for the rocker to work against [a good thing]. I assume that you may have rocker geometry problems with short valves. Some experts may be better able to advise.
Dave
: ARE LASH CAPS SAFE? HOW MUCH MORE EXSPENSIVE IS
: IT? wHAT EXACTLY WOULD HAPPEN IF THE VALVE
: IS SHORTER, LOSS OF RPM? LOSS OF TQ? LOSS OF
: HP? pOSSIBLY BETTER, WHO KNOWS? tHANX
