| carter bbd problem https://slantsix.org/forum/viewtopic.php?t=28306 |
| Author: | dclxvi [ Wed Apr 09, 2008 7:50 pm ] |
| Post subject: | carter bbd problem |
today i was loosening my fuel line on my carter bbd when the fitting behind it broke. does anyone know where to get a new one. it has to have the right size inside hole for the rubber tipped needle to seat to cut off the fuel flow. |
| Author: | SlantSixDan [ Wed Apr 09, 2008 8:23 pm ] |
That's the fuel inlet seat. It comes in a carburetor rebuild kit. |
| Author: | dclxvi [ Thu Apr 10, 2008 8:18 am ] |
thanks, i thought it might but none of the part stores around here have one to look at. |
| Author: | volaredon [ Thu Apr 10, 2008 11:55 am ] |
What do you mean, the parts stores don't have WHAT to look at? A carb, a rebuild kit or a inlet nut/needle&seat? That "nut" has come with every carb rebuild kit I have ever bought for a BBD. If they'd pull their PAPER catalogs, often these parts were listed as seperate part numbers, but unless your carb is very freshly rebuilt, youd be better to buy a kit and go thru it anyways. |
