| 1965 speedometer cable to a 1970 trans? https://slantsix.org/forum/viewtopic.php?t=28371 |
| Author: | evilgenius [ Mon Apr 14, 2008 4:58 am ] |
| Post subject: | 1965 speedometer cable to a 1970 trans? |
Can the speedometer cable and pinion gear from a 65 valiant be matched to a 1970 904 trans? I'm trying to figure out if I can continue to use my car's gauges to work with the newer transmission. |
| Author: | Charrlie_S [ Mon Apr 14, 2008 5:40 am ] |
No, but a 1966 Valiant speedo cable will work. It has the correct end for the 65 speedo head, and the 1970 trans. |
| Author: | SlantSixDan [ Mon Apr 14, 2008 6:56 pm ] |
Yep, the cable you need is a '67-'70 Dart or Valiant item. |
| Author: | Charrlie_S [ Mon Apr 14, 2008 7:16 pm ] |
Quote: Yep, the cable you need is a '67-'70 Dart or Valiant item.
Dan, didn't the connection at the speedo head change from the screw on to the snap on, between 66 and 67?
| Author: | SlantSixDan [ Tue Apr 15, 2008 5:55 pm ] |
Pretty sure the plastic push-on connection came out for '71, but I could be wrong. Lemme look... ...*time passes, keyclick noises*... Looks like you're right; the cable needed is a '66-'67 only item. ATP #Y803. Learn somethin' new every day, thanks for the correction. |
| Author: | evilgenius [ Sun Jun 08, 2008 1:29 pm ] |
can the screw on plug of the later cable be used to 'retrofit' the older cable? |
