It is currently Sat Nov 21, 2026 2:09 am
PostPosted: Sun Apr 20, 2008 7:08 pm
Hey guys. I need to build somthing to hold a slant for a couple months in the back of my truck normally I'd just build a crate that sits where the oil pan bolts up(did that on my 318) but the slant has an odd oil pan mount. I have two that I'll have to store in the back of my ramcharger and I don't want them flopping around on tires.
PostPosted: Mon Apr 21, 2008 7:15 am
How long you planning on having it sitting back there? I'll be picking up a slant from a member in Kent, WA when I get back stateside and taking it 300 miles to Spokane. I'll just be putting a sheet of plywood on the floor of the cargo compartment of my truck, setting a spare tire on it (for the low part of the oil pan to sit inside), setting thick plastic on that, setting the engine in, wrapping the plastic around the top of the engine, then strapping it all down with a couple cargo straps to secure it. It'll be fairly easy for me since I have tiedowns on the floor of my cargo area.
The plastic is just so I don't have to smell fuel, oil and coolant that might still be in/on the engine during the drive back to Spokane, and to contain any drippage from the engine.
PostPosted: Mon Apr 21, 2008 8:09 am
Car Model: 1967 Dodge Dart GT
dad and i used the tires/tarp method to haul a slant/trans about 3 hours in the back of his caravan, we had extra tires on the sides in case it decided to roll, tie downs would have been better :)
PostPosted: Mon Apr 21, 2008 10:22 am
I have an engine dolly that I got from a guy up by Detroit. It was home made and did not look too complicated. It even has wheels on it so it rolls around easily. :lol:
I also have one he made out of a shopping cart, but the engine lays on it's side in that one. Also very simple. :D
PostPosted: Mon Apr 21, 2008 11:17 am
I use the $17 movers dollys. They work great on V8's. OK for slants (better if the trans is attached)_
PostPosted: Mon Apr 21, 2008 4:37 pm
I'll probably do the same thing but build a crate to support the body and keep it in the same position as it normally would be. It's going to be sitting in the back for a couple months at the least and I'll have it wrapped up and everything.
PostPosted: Mon Apr 21, 2008 7:28 pm
old tire/ 1 block of wood(4x4) & some harbor freight straps will hold for a long time. Lawrence
