| Rocker Shaft Spacers Needed https://slantsix.org/forum/viewtopic.php?t=2839 |
| Author: | XMAN [ Tue Nov 06, 2001 4:40 pm ] |
| Post subject: | Rocker Shaft Spacers Needed |
In building up my 225 I have a couple of rockers that are not quite lined on the valve stems. The stock spacers are not worn but still there is a fair amount of play up and down the shaft. 1. Where can you get spacers or shims for the stock assembly? 2. How much play should the rockers/shims have on the shaft? usclstaffingnet@sprintmail.com |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Nov 06, 2001 6:41 pm ] |
| Post subject: | Re: Rocker Shaft Spacers Needed |
: In building up my 225 I have a couple of : rockers that are not quite lined on the : valve stems. The stock spacers are not worn : but still there is a fair amount of play up : and down the shaft. 1. Where can you get : spacers or shims for the stock assembly? 2. : How much play should the rockers/shims have : on the shaft? I just go to the junkyards and grab some extras. I make sure to get a few of the wider center spacers which can be ground down to fit other locations. Also note that some of these have a longer / larger "bump" which can be positioned to center-up the tips to the stems. One other way to do this is to contact Rocker Arm Specialists, they have "shaft washers" which can be used to take-up the slop. DD |
