| Exhaust manifold https://slantsix.org/forum/viewtopic.php?t=28392 |
| Author: | GupEBoy [ Mon Apr 14, 2008 11:12 pm ] |
| Post subject: | Exhaust manifold |
I was wondering if anybody has experiance with this exhaust manifold? As you will see, I haven't had much luck this weekend. http://www.1aauto.com/1A/ExhaustManifol ... 009/568470 They took a picture of port side. Only thing missing is stid to center intake manifold. ![]()
| Author: | mopar_nocar [ Tue Apr 15, 2008 6:17 am ] |
I had one, it was a nice piece. sb |
| Author: | GupEBoy [ Tue Apr 15, 2008 7:51 am ] |
Thanks sb, can you tell me if the center hole is threaded to accept the bolt for manifild? Is ribbing thicker. I may want to smooth out the exhaust ports. is there enough meat to do so? Thanks again. Jim |
| Author: | Matt Cramer [ Tue Apr 15, 2008 8:27 am ] |
I have one of these manifolds on my Dart. It does have the correct threads and a bit more rib than a stock manifold. The bad news is that the casting quality was not up to late '70s Chrysler quality control standards - there was casting flash and huge parting lines everywhere, including places that shouldn't have parting lines. I've heard of a few that had a port blocked with casting flash and had to clean it out. It's a pretty close copy of stock manifold off a later version with the feedback carburetor so wall thicknesses are the same. One other note: 1A Auto checks to be sure the parts fit the vehicle listed. While normally this would be good customer service, they don't quite realize that this manifold fits a lot more applications than the ones they listed. |
| Author: | 65Dodge100 [ Tue Apr 15, 2008 8:43 am ] |
| Author: | mopar_nocar [ Tue Apr 15, 2008 10:14 am ] |
Ditto what these guys said, but I didn't have any of the problems...just lucky I guess. It came with the triangle washers, heat riser sheet metal and all the intake to exhaust bolts except the center one. I was doing well at last I heard. sb |
