| ballast resistor https://slantsix.org/forum/viewtopic.php?t=28406 |
| Author: | dclxvi [ Tue Apr 15, 2008 7:09 pm ] |
| Post subject: | ballast resistor |
i have a 74 valiant with an msd 6a on it. my question is do i still need the ballast resistor and if not which wires do i need to connect straight to eachother |
| Author: | Sam Powell [ Tue Apr 15, 2008 7:59 pm ] |
I think you do need the ballast resister, but am not absolutely sure. You should ask them. But if you do not, simply jump the blue and brown wires at the ballast resister. Make a jumper wire to connect the two sides of the ballast resister. I think I ran mine for years without a ballast resister. But again, just check it out first to be safe. Do you still have your instruction sheet? If not. I will look this up in mine, which are filed away. Sam |
| Author: | emsvitil [ Tue Apr 15, 2008 8:21 pm ] |
How are you triggering the MSD? |
| Author: | Joshie225 [ Tue Apr 15, 2008 9:04 pm ] |
Read the instructions! http://www.msdignition.com/1download.htm |
| Author: | dclxvi [ Wed Apr 16, 2008 7:29 pm ] |
i figured it out, thank guys. i am running the msd without the ballast or the ecu. |
| Author: | Sam Powell [ Wed Apr 16, 2008 7:32 pm ] |
Gosh Joshie, that doesn't sound very daring, or adventuresome or creative. It guess it might work though. DCLXVI, let us know if you get it working OK. Is your name your birthdate in Roman numerals? I'm sorry I am not literate in Roman numerals once it gets over XXIII. I can;t even remember what Super Bowl it is, and I am a huge football fan. Sam |
| Author: | Joshie225 [ Wed Apr 16, 2008 7:58 pm ] |
Sam, There are at least two different ways to interface MSD with stock ignition, bypass the stock ignition, etc so in the interests of brevity, expedience and not guessing I posted the obvious. Plus I linked to the instructions. Not everyone wants to be as daring and creative with their electrical system and you. |
| Author: | dclxvi [ Wed Apr 16, 2008 9:33 pm ] |
the ignition works great. ive been running the msd per the instructions from msd, but since yesterday its running and starting a hundred times better because i eliminated the ballast resistor. DCLXVI=666. |
| Author: | Sam Powell [ Thu Apr 17, 2008 6:07 am ] |
Quote: Sam,
I was joking. Thanks for the link.There are at least two different ways to interface MSD with stock ignition, bypass the stock ignition, etc so in the interests of brevity, expedience and not guessing I posted the obvious. Plus I linked to the instructions. Not everyone wants to be as daring and creative with their electrical system and you. Sam |
| Author: | Sam Powell [ Thu Apr 17, 2008 6:09 am ] |
Quote: the ignition works great. ive been running the msd per the instructions from msd, but since yesterday its running and starting a hundred times better because i eliminated the ballast resistor. DCLXVI=666.
Devilishly clever. Sam |
