hose inlet
https://slantsix.org/forum/viewtopic.php?t=28407
Page 1 of 1
Author:  oo3 [ Tue Apr 15, 2008 8:17 pm ]
Post subject:  hose inlet
thru the search i was able to answer some of my cooling questions - (such as no longer able to buy rad hoses with springs) - i need to replace the inlet metal pieces for the heater hoses on the engine block - i did not come up with much in search because i am sure i am not using correct term - anyways where can i purchase these? - thank you - oo3
Author:  ceej [ Tue Apr 15, 2008 8:44 pm ]
Your local parts store has them. You want the 5/8" ones.
Author:  Joshie225 [ Tue Apr 15, 2008 8:57 pm ]
Later model cars have two different size heater hose fittings. Look at the heater hoses and see if they are both 5/8" or if one is 1/2", but if you're speaking of your '66 A100 they will both be 5/8"
Author:  oo3 [ Fri Apr 18, 2008 12:33 am ]
not having succes removing the nipple yet - tried penetrating oil and visegrips - applying heat and cooling multiple times - has not broken off yet but wont budge - what next? - oo3
Author:  LUCKY13 [ Fri Apr 18, 2008 1:39 am ]
Take a hammer and start taping it lightly, tap in adirection like you was trying to drive a nail. Dont get to hard with because your not trying to beat it loose really, all your doing is jarring the threads so that the penitation oil can, well, penitrate. Use the hammer in a way that it kinda just bounces back off and do this for 20 or 30 times ( striking the hammer). AFter you use the hammer spray with oil and let set a hour. Then repeat doing the same thing. Let set a hour again, then repeat again. After about four rounds of this then try with your vise crips try working the pipe back and forth. If its not coming loose start with the hammer and oil again. Sooner or later it will start moving, just dont get in a hurry and let the vibration from the hammer strikes and the oil do there job.
Jess
Author:  tlrol [ Fri Apr 18, 2008 5:06 am ]
Post subject:  Regarding stuck inlet
Do you have to drive the car? If not perhaps you can goop on some Naval Jelly for a few hours and dissolve the external rust. Hose it off when finished and reapply--do the light tapping with the hammer thing (as previously described) and walk away for a few hours. Hose off and re-apply/do over. Hose it off after another few hours. Douse with various flavors of penetrate--I did this for 3 days and that things spun right out. Be patient if you can be...penetrating oils really do work if they are applied in quantity and given time to do their magic. Good luck!
Author:  oo3 [ Fri Apr 18, 2008 10:18 am ]
i actually did a little of the hammer bit but not to that extant - will do more over the weekend - i dont have to drive the van any time soon - while i have things apart i will also bring the radiator to a shop for check out - replace the water pump and timing set - have not had cooling problems but this being a van i want to make sure everything is well as they seem to be more prone to such conditions - and they are also a little more of a pain to work on than the cars - thanks - oo3
Author:  oo3 [ Sat Apr 19, 2008 5:33 pm ]
like they said take your time and its out - i also ended up using a pipe wrench as the vise grips just kept slipping - thanks - oo3
Author:  tlrol [ Sun Apr 20, 2008 7:41 pm ]
Post subject:  hosed...
Pipe wrench for a pipe...seems fitting...
