| drags https://slantsix.org/forum/viewtopic.php?t=2841 |
| Author: | andrew wagner [ Tue Nov 06, 2001 5:15 pm ] |
| Post subject: | drags |
Over the weekend I was at the drags and my best time was 15.20 @ 90mph. That is 2 mph faster then before but a tenth slower. That tenth was in my 60ft time only 2.17 to a 2.06 last time. I had problems at the starting line, I was torquing it up to what I had before and that would not get it to pull boost on the line. So I had to all but start to spinn the tires on the line to spool up the turbo then i got the 2.17. I put a 600 dp holley on and I don't think that the stock fuel pump is keeping up. The car would fall on it's face about 100 too 150 feet before the finish line. The only way I got it to pull in third was back off to about half throtle once I shifted to third. Even with all of this was going on I did make it to the 3rd round with rt's of .517, .518,and a big fat red light with a .497 the third round. Tonight I cut off the choke tower lowered the sec. jets to 80s and increased the pim. to 76s. I also ordered the holley 110 gph electric fuel pump, 3/8 fuel line to feed the mech. pump. If that does not work I am going with the mallory reg. The good thing is that I have all winter to tune it for that 14 sec. run that I want!!!! andrew wagner |
| Author: | Dart270 [ Tue Nov 06, 2001 8:20 pm ] |
| Post subject: | Re: drags |
: Over the weekend I was at the drags and my best : time was 15.20 @ 90mph. That is 2 mph faster : then before but a tenth slower. That tenth : was in my 60ft time only 2.17 to a 2.06 last : time. I had problems at the starting line, I : was torquing it up to what I had before and : that would not get it to pull boost on the : line. So I had to all but start to spinn the : tires on the line to spool up the turbo then : i got the 2.17. I put a 600 dp holley on and : I don't think that the stock fuel pump is : keeping up. The car would fall on it's face : about 100 too 150 feet before the finish : line. The only way I got it to pull in third : was back off to about half throtle once I : shifted to third. Even with all of this was : going on I did make it to the 3rd round with : rt's of .517, .518,and a big fat red light : with a .497 the third round. : : Tonight I cut off the choke tower lowered the : sec. jets to 80s and increased the pim. to : 76s. I also ordered the holley 110 gph : electric fuel pump, 3/8 fuel line to feed : the mech. pump. If that does not work I am : going with the mallory reg. The good thing : is that I have all winter to tune it for : that 14 sec. run that I want!!!! : : andrew wagner Great stuff Andrew! Keep up the good pressurized work. I'm sure some of us will be borrowing technology from you later. Lou |
| Author: | Charlie Schmid [ Wed Nov 07, 2001 12:31 am ] |
Andrew, Keep up the posts. I used to run a turbo slant and am very interested in your progress. Hope to get mine back together over the winter. Charlie Quote:
: : Great stuff Andrew! Keep up the good : pressurized work. I'm sure some of us will : be borrowing technology from you later. : : Lou flturbo6@aol.com |
