| T3 boost pressures and injectors https://slantsix.org/forum/viewtopic.php?t=28415 |
| Author: | praxis [ Wed Apr 16, 2008 2:07 pm ] |
| Post subject: | T3 boost pressures and injectors |
Are any of you running a single turbo t3 ? If so series 50? If so what type of boost pressures do you run at? And what lb injectors do you use? If you don't mind me asking? I will be running a t3 series 50 for loww rpm boost and was wondering if anyone else was and what type of results you were getting? thank you for your time and patience |
| Author: | runvs_826 [ Mon Apr 28, 2008 10:32 pm ] |
Look for Matt Cramer's stuff. You'll have to do a search for it, unfortunatley I don't recognize what turbo your talking about and I'm semi-knowledgable about those. I would stay clear of the ebay specials that say a trim number and 6 ricers that it could fit on. Also, the eclipse and 2.2L turbos are wayyyyyy to small. Boost down low is useless, what you want to read about is where your engine's breathing needs will fall on the "turbo map" and select accordingly. The middle of the "island" is idea for what you want, that way the engine will work with the turbo all the way through the rpms and not the other way around at a certain rpm. |
