It is currently Sat Nov 21, 2026 7:19 pm
 Post subject: Which kit do I need ?
PostPosted: Sun Apr 20, 2008 12:49 pm
I have a Holley 1920 and there are to set of numbers above the fuel bowl (3220 and 4656) and a set of numbers on the side (12R-4285B) .
Which float will be good to get ( Holley 362 B77). I think it is called the hot idle compensator valve ,does the seal or oring come with the kit.I was looking at it ,and when I took the valve out , the o-ring on the bottom looked like an 8-ring.
What do I have took take off from the inside of the carb to dip. I see on the metering body ,there is a pastic piece that is under the economizer plunger? and pushes into the checkball , I am pretty sure that needs to go (if so how hard is it to take off and put back on ).
Thanks
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sun Apr 20, 2008 1:09 pm
Type #4656 = Holley 1920 for 1971 Dodge/Plymouth with 225 engine, automatic trans, Federal/Canada emissions.
Float is a Walker # 100-14.
Kit is a Walker # 15480A, and does include new seals for the hot idle compensator valve.
Metering block does not get dipped in carb cleaner. Use the plastic straw on a can of spray carburetor cleaner to blast-clean the various accessible passages.
PostPosted: Sun Apr 20, 2008 1:20 pm
Thanks Dan
That is why it is best to ask if you don't know.
As soon as i get my distributor ,I will have everything I need for the HEI conversion.
Dave
81 Dodge D150
