JEGS 40105 - JEGS High Energy Coil ?
https://slantsix.org/forum/viewtopic.php?t=28447
Author:  Scott H [ Fri Apr 18, 2008 6:38 am ]
Post subject:  JEGS 40105 - JEGS High Energy Coil ?
I have an 80 volare with a slant six. This is a daily driver and I am trying to get it to start quick and run as good as possible.
It has the original MOPAR brand coil. and is all original.
I am not quite ready to go the GM HEI route (im thinking of taking it to Carlisile this year as a survivor).
DOes anyone have experience with the JEGS 40105 - JEGS High Energy Coil http://www.jegs.com/i/JEGS/555/40105/10002/-1 It seems like it might help and is relatively cheap. There are no specs on the JEGS site so I cant tell how in might compart just by looking at numbers.
Thanks,
Scott
Author:  SlantSixDan [ Fri Apr 18, 2008 7:41 am ]
Now more than ever, I try to avoid generic stuff like this. No way to tell who made it, and to what specs. More than that, there'd be no performance advantage of just sticking a coil like this, even a name-brand one, in place of your factory coil.
Author:  emptypockett [ Fri Apr 18, 2008 8:14 am ]
Post subject:  jegs coil
I have a 1978 Volare and the best thing I did when it was stock to get it to start better was to install a Mopar gear reducted started.You can get those from Jegs in the Mopar section of the cataloge about $147.00 .The motor should be in good tune but these things crank them over much better and allows the engine to fire quickly. :idea:
Author:  SlantSixDan [ Fri Apr 18, 2008 8:59 am ]
There are a lot of more-important, higher-benefit places to spend $150 before replacing a working starter motor. The Nippondenso mini starters used from '89-up do crank the engine faster than the Chrysler-built starters used from '62-'88, but an engine in good condition and proper tune starts just fine with a factory-equipment starter.
Author:  Joshie225 [ Fri Apr 18, 2008 11:10 am ]
Dan's right. $150 spent on making sure the fuel and ignition systems are in top shape is a much better investment. Having said that, an engine that's in poor mechanical condition will never perform well. Do a valve adjustment and then a compression test. If the compression is low a better starter will only mask a starting issue. You'll still be down on power and economy.
Also, there are plenty of good used Nippondenso starters in wrecking yards. I have yet to pay more than $50 for a perfectly good used one. I like the weight loss and faster cranking, but the car does loose some character. Most car people can easily identify a Chrysler starter. It's funny when TV and movies dub in old Chrysler cranking sounds for other brands of vehicles.
Author:  Scott H [ Fri Apr 18, 2008 12:00 pm ]
This car has 59k original miles. I have the standard bluestreak dist cap. Echlin rotor, good wires and plugs all to go into the car as soon as i can get to it. I have not driven it yet except for on and off the trailer and it takes some cranking to get it started. it was only sitting for about 3-5 years in a garage years so it is not too bad.
Scott
Author:  SlantSixDan [ Fri Apr 18, 2008 12:31 pm ]
Focus on checking and correcting the conditions that can cause extended cranking. They are mostly fuel-related. Check the operation of the choke (maybe put in one of the adjustable Electric choke kits), go through the carburetor with a good-quality rebuild kit, maybe do the fuel line mod, and suspect leaky valves in a fuel pump that's been sitting for so long, so replace the pump.
Author:  LUCKY13 [ Fri Apr 18, 2008 1:26 pm ]
440Source has these starters for $89.95 if a new starter was wanted. The guys running them on big blocks have had good luck with there starter so it should work fine for the slant.
I will have to agree with the others though, fixing the problem itself would be the best way to go about this. Chances are it is fuel related but you might want ot check and make sure it has good voltage on the hot side of the coil with the ignition in the start & run possitions. Even something as simple as new plugs can make big diffs sometimes.
Jess
Author:  Aggressive Ted [ Fri Apr 18, 2008 1:41 pm ]
Scott H,
To answer your question on the coil, if you think it needs replacing, I followed Dan's upgrades just short of the HEI mod. I purchased the chrome MSD Blaster 2 coil and replaced the Mopar resistor (1.5 ohms) with the MSD (.85) ohm resistor that comes with the coil. The starts are awesome! I am running the NGK plugs gapped at .040 and MO-3000 rotor and Bluestreak cap, 8mm wires, Orange ECU. I must say that it is the most trouble free setup I have used. It starts right up!
Just be sure your getting good fuel delivery. That can be a weak link and could cause poor starts.
Author:  SlantSixDan [ Fri Apr 18, 2008 1:53 pm ]
Very likely Chinese copycats, which have flooded the market. Danger, warning, caution, etc.
Author:  Mopar-or-no-car [ Mon Apr 21, 2008 8:13 am ]
i agree with what is said
top notch ignition then make sure fuel system is operational.
I am going to do both on the old girl this year except I am going HEI
oh yeah how about a valve lash adjustment and timing check while we are in there, hope that helps
