| Performance: Boring and Pistons https://slantsix.org/forum/viewtopic.php?t=28465 |
| Author: | runvs_826 [ Fri Apr 18, 2008 7:31 pm ] |
| Post subject: | Performance: Boring and Pistons |
Ok, well this time around pop's and I are going to get serious with our slant six. I'm 20 now and have full permission to build my hemi from the old man, but what's the challenge in that? Ok, we are going with a lot of boost and that is great. But I still need to prep the rest of my engine. My head is ported and polished and ready to go. We're going with bigger valves, the plan is to cut down my old intakes to 1.55 and do something similar with some small block valves. As cheap as I can think of getting large valves. That being said we're going to need to large up the bores. I know people have talked about stroking, but I think it's been proving and pretty much given we have enough stroke so time to think about the bore.... Does anyone make a forged piston anymore? I know some people have used Arias, does anyone have a price for these custom pistons? I'm assuming in the $500 range. So this leads to the question that I need answered. What can we open the bores to? I looked backed at no one has done a massive wet sleeve or anything like that. The forged pistons from the v8's (ie 350) are relatively cheap even including the sleeving costs. So I need some ideas! If I can open the bore up to 4.00 were at 311 cubes so I think it's time to push the envelope. Thanks for all help, and even general performance ideas for the short block is appreciated. |
| Author: | slantzilla [ Sat Apr 19, 2008 4:26 am ] |
I seriously doubt you can get a 4.00" bore when the block is on a 4.00" bore center to start with. I just bought a set of custom Ross forged nitrous pistons for 3.5" bore. Cost was $60 per piston until we moved the pin height. Then it became $100 per piston. If you're going to boost it, CI will not make that much difference, especially when you factor in the small ports and valves we have to work with. Just asking, but will intake valves stand up to the heat on the exhaust side? |
| Author: | runvs_826 [ Sat Apr 19, 2008 10:54 am ] |
Yeah, I didn't think 4in would happen that's why I was asking what the max might be. There's some pistons availble forged from Summit that are 3.7in or so. There's plenty of options! Thanks for the Ross insight, I'll probably still go with that option if all else fails. I thought they would be a lot more. I know CI won't make a difference, but in the fear of not meeting my hp goal or just building something the pushed the envelope 50 more cubes is going to be a lot safer bet for a 4.125 stroke than trying to eat the cubes and cost of destroking it for more RPMs. Any thoughts there? I don't know about the valves for sure. What we might end up doing is getting some 350 burnt valves or leftovers from the local shop and trimming those down, and putting some 11/32 guides in. The idea is we got the lathe and the foundry starting working so we might as try to build as many things as possible. Hope for my ideas, thanks for the input Zilla. |
| Author: | Joshie225 [ Sat Apr 19, 2008 11:46 am ] |
3.5" is the max bore I would run on a boosted engine. If you want much bigger it's going to require sleeving and it's spendy to do right. You could do Siamese sleeves like on a Honda if you wanted to spend real money. Also, you'll want better than stock quality exhaust valves if you're going to run it more than 1/4 mile at a time under full boost. |
| Author: | runvs_826 [ Sat Apr 19, 2008 1:16 pm ] |
Well, if I can get enough cubes out of it I wouldn't mind doing a sleeve set-up. Wet sleeve doesn't look like it will be worth it, I read an article where they did that to punch out 426 on the new hemis. However, for a regular sleeve set-up I believe I could break even if I got large enough bore to get a set of v8 pistons. Good point about the valves. Will keep that in mind of just mismatching some bigger valves and cutting as necessary. |
| Author: | slantzilla [ Sat Apr 19, 2008 4:06 pm ] |
There was a guy on here a couple years ago doing a sleeved block to get a bigger bore. He got as far as boring the cylinder walls out and then I think the project died. As for the CI vs. RPM thing, here again, all the RPM in the world is going to be useless if you don't have the grunt to get the car moving and get the motor into the powerband. CI is not really necessary with boost. Cameron Tilley makes some serious steam with his motor and a turbo. He also has a mega dollar fuel system. |
| Author: | runvs_826 [ Sat Apr 19, 2008 4:55 pm ] |
Could you expand on the fuel system? I'll go check over at Mopar Market here soon to see what I can round up, but a direction would be nice. The CI vs RPM thing was badly explained. I meant since we already have a long stroke I might as well add a bigger bore and redline at 6000rpm. I think that will be more than enough! So, I think the goal is for a 3.7 in bore which I can get a good set of forged pistons for relatively cheap from the look of it, so another $60 or so bucks a cylinder should give me some more cubes right? Keep the good info coming Zilla going to need all the help I can get. Any short block secrets? |
| Author: | Bren67Cuda904 [ Sat Apr 19, 2008 5:15 pm ] |
Your going to spend alot on sleaving that block to get to 3.7. I bored to 3.592 and thats the max on a block with NO core shift, which is hard to find. I wouldn't boost a block with that much bore (3.592). What some are saying is to keep the stock stroke and get some good pistons in the 3.4-3.5 bore range and boost the hell out of it. A bore in that range is more likey going to hold the higher boost than one thats bore way big and has less boost on it. Short block secrets? I think the biggest is ARP everything and if you add a ridiculous amount of boost also add prayer. |
| Author: | slantzilla [ Sat Apr 19, 2008 7:06 pm ] |
The major benefit to a bigger bore is that it unshrouds the valves some more and lets the head flow a little better. My good motor is at 3.465", and my new shortblock is at 3.5". My shortblocks have nothing fancy in them at all. ARP rod bolts and that is pretty much it. The only oiling system mods top the block are a little relieving around the passages under the oil pump where the oil makes the turns from the pump into the galleries. Doug blue-printed my pump and put a hardened gear on it. I do have Jeffrey windage tray and a Johnson crank scraper. Pan is unbaffled stock. I do not subscribe to a lot of high dollar trick-of-the-week parts. I went with these super-duper nitrous pistons to try and get more longevity out of the motor on high doses of hose. Mike Jeffrey himself disassembled my motor once and claimed it could not run what it does with the parts in it. As for Cameron's fuel system/engine controller, he is very tight-lipped about it. Lou probably knows something but has been sworn to secrecy. If he tells, Aussie ninjas will hunt him down and kill him. |
| Author: | runvs_826 [ Sun Apr 20, 2008 3:23 pm ] |
Well thanks for the input. It's not so much the fact I want more cubes, it's the fact that forged pistons would be semi-expensive for the slant. So the thought was to get cheaper forged pistons and open up the bore a little bit. Cubes would simply be a by-product. The bigger valves to would work more efficently, since I'm not totally convinced 1.77/1.44 is optimal for a stock bore. Boost is going to start at 10lbs testing and work it's way up to 20lbs. The fuel managment will be the megasquirt system, with a trigger wheel for the ignition. The turbo I'm choosing is probably going to be a T61, with cooler and water. The other thing we want to play with is flash steam going into my exhaust before the turbo to help the spool. Essentially the water will flash and expand 1000:1 in volume which might help drive the turbo. Just an idea, probably won't do much since no one has done it. The computer would simply have an if-than statement that would feed the water from off-boost to 8-10lbs. All in all thanks for the input. |
| Author: | runvs_826 [ Sun Apr 20, 2008 4:35 pm ] |
Ok, well after lot's of searching, to wet sleeve the engine you need somewhere around a .2-.3 wall for each cylinder. So for a 4.00in bore spacing it would actually reduce the piston size to 3.3X. So I will have to finally side with what everyone has done and bore her out to 3.5 and all her good. Thanks for all input |
| Author: | LUCKY13 [ Sun Apr 20, 2008 8:59 pm ] |
A 3.504 bore will work out good anyway. There are many rings sets available in this size and you can get the custom pistons setup to use these rings which come in a lot of the imports and they are a very nice setup. Venola is one company that builds the forged pistons for the slant six and they can make them work with the import rings which has less drag and will give extra power. If you want the best I suggest getting CP to make you a set of pistons, but they will cost. You will not have any trouble spooling a T61 turbo. If you get one that is ballbearing and has the newer wheels ( like the F1 exhaust wheel) it will spool so quick you want know how to act. Even the new PT6776dbb spools quick enough that the Buick guys are getting by with only a 2800rpm convertor. This turbo is pushing pure stock Buick Gn's into the low 11's - high 10's without doing anything to the engines. A Slant Six with a 3.504 bore would spool it like nothing and make just as much power, plus have the benifit of a lighter body (Buicks weight around 3800lb) and also get by with about the same convertor. Jess |
