It is currently Sat Nov 21, 2026 3:43 pm
PostPosted: Tue Apr 08, 2008 10:14 pm
hi guys, mine name is Jason. ihave a 64 dart 225 /6. picked it up for a good deal. redid the interior,lowered it,and some wheels and tires and absolutly love the thing. I went throught it adjusted the valves, new points,cap,rotor,wires,plugs and rebiult the carb and the thing runs great. Also went throught and fixed all the oil leaks. I have put alot of miles on it and cant belive how good it runs. now the question i have for you guys I want performance. With a super six set up would i feel a difference? or would i be better off with the clifford (or like) intake and header setup. I am pretty sure i will add a cam pretty soon as well if you guys recommend it.If i could get your guys opinion that sure would help Thanks in advance, love the website
All in a days work
PostPosted: Tue Apr 08, 2008 11:09 pm
I was never impressed with the Super Six.... but for the money you will notice the difference. Honestly if you can afford the Offy and headers go for that. The cam and shave (.1 decking) will really liven your little engine up. But the four barrel and headers, or bolt-ons in general only improve what the engine is already doing. So if it's tired and such a %20 increase won't be worth the money. Does that all make sense?
Also, don't forget about gears, they really help!
PostPosted: Wed Apr 09, 2008 6:11 am
I installed a Super Six and Dutra Duals at the same time, and it was a night and day difference to me. Made the car SO much more enjoyable to drive. I think it's an excellent step up over stock. But if you're sure you're going with a 4bbl eventually, I might just go straight to that.
My future plans are to skip the 4bbl entirely and go to MPFI. Of course, that new M90 blower intake might change everything... <sigh>
vm
PostPosted: Wed Apr 09, 2008 6:39 am
A super 6 will make you just as fast as an OFFY without cam and compression.
I have seen lots of 19 second slant 4 barrel cars.....and lots of 19 sec slant 1 barrel cars. The difference is $$$$
Get a super 6 and bigger exhaust (2 1/4") and use the saved money to start a real motor.
PostPosted: Wed Apr 09, 2008 5:29 pm
Thanks for for the advice sounds like I will go for the offy and headers,do you guys recommend the clifford set up? And if I go with the cam which Iam pretty sure I will do I have to pull the head? And which cam do you think?,I do not want to change my converter but would like the lobe at idle.Thanks agian in advance. I hope to have pics up soon
All in a days work
PostPosted: Wed Apr 09, 2008 6:06 pm
Sorry but I'm having a hard time relating the cam to the head? Honestly I believe you need to pull the whole engine to change out the cam. Up the compression with a cheap head shave of .1 if your going to tear the actual engine out.
Offy is what I pefer, but that is because I have bad relations with Clifford. Something to do with over-priced and don't deliver (literally!). Honestly unless you have gobs of cash to throw at it right now I would get your intake set-up(which I happen to have a NIB one), and change out your cam and compression bump. I would save the headers for last based on there costs - noticeable gains. A higher stall or better rear end gears might even come first or at least start to get on the drawing boards.
PostPosted: Fri Apr 11, 2008 10:44 pm
Can a intake be bolted up without a header. The reason i ask is on clifford's site they say header required for intake install
All in a days work
PostPosted: Fri Apr 11, 2008 10:46 pm
Offy intakes fit with the stock exhaust manifold.
PostPosted: Sun Apr 13, 2008 11:33 am
Thanks joshie225, I will be on the market for a Offy then. Just to throw it out there, does anyone have a set of headers they want to part with. Willing to pay what headers are worth.
All in a days work
PostPosted: Sun Apr 13, 2008 2:45 pm
Might want to drop a thread in the part's wanted section. If not talk to clifford now so you can get a set by Christmas.
Clifford Performance
Also, Hooker had some stuff that just came out so Search for that.
PostPosted: Sun Apr 13, 2008 6:26 pm
The Hooker Headers are a very nice piece and i believe they may be the best set out there for most slant builds. The only think is I dont know how good they are going to fit a early A body car. I believe they are intended for 67 & up A body's but I am not sure on that.
With a early A body I believe I would go with the Clifford headers
( because of clearance & room). But I would extend the collectors on them about 12 to 16 inches depending on the RPM range I wanted the engine to peak horsepower at. There is a lot of power gains with the right lenth collectors on a header and many in the torque which helps drivablity alot.
Keep you eye out on Ebay for a set of Clifford Headers, there seems to be a set come out about every week.
Jess
PostPosted: Sun Apr 13, 2008 6:57 pm
Does anyone have the link of a place to get the hooker headers?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sun Apr 13, 2008 7:18 pm
Summit Racing
HOK-5602HKR
http://store.summitracing.com/egnsearch ... 4294840127
PostPosted: Sun Apr 13, 2008 7:49 pm
Lord, those are pretty!
1975 Duster 225, same thing in a van.
Also a bunch of Neons.
PostPosted: Sun Apr 13, 2008 7:59 pm
Thanks Ted. Hmmm now I might have to get those!
Ronnie
