| Slant six carbs.... *lots of pics* https://slantsix.org/forum/viewtopic.php?t=28466 |
Page 1 of 2 |
| Author: | DusterIdiot [ Fri Apr 18, 2008 11:02 pm ] |
| Post subject: | Slant six carbs.... *lots of pics* |
While I was cleaning and organizing the shop over the last couple of days I decided to start grouping my carb pile and getting ready to 'weed' out the extra carbs I don't need / rebuild them... With the interest lately on different slant carbs I decided to take some pics for 'show and tell'... Here's part of the pile, Carters/Stromberg on the left, Holley 1920's middle, Bigger Holley 4000, 4150/60's to the right (you may be able to spot the stock Feather Duster 1945 in the back middle with it's vacc. governed can) The stromberg was a very simple carb with not many parts to disassemble... in fact I like the fact the main body has a removable venturi (wish they made a larger passage version to swap in, I'd hate to hone this one a bit and ruin things...) The next most simple 1 barrel would be the Carter BBS with it's split venturi and instead of boosters it has nozzles much like the TQ family... Holley's 1920 would be next in line, with a few booster changes over the decades... in this pic the left one is a 1967, the middle is from a 1961 Ford Van with the 144, and the right is off a 1973 Dart Sport. Another variation is the later economaster carbs, and some were equipped with the 'spiderweb' booster for better signal (much like the reverse screw emissions Holley 2300 carbs for late model Fords) Holley 1945 is pretty easy to spot with it's bullseye venturi and the 'fatter' body with the floats and bowl designed into the body.... For two barrels that are a direct fit/stock to the two barrel manifold you get two choices: Carter BBD on the left, middle has a 'stock' choke attached to it, and the Holley 2280 on the right (designed as the replacement for the BBD on 318 vehicles in the late 70's...) Hope this helps some of the 'new' guys out when reading posts about carbs, or at least helps to identify what somebody might have on their car/ looking for on their junkyard adventures... When I pull these apart for rebuilding, I'll take some pics so there's some reference on the internal differences of these carbs.... -D.Idiot |
| Author: | ceej [ Fri Apr 18, 2008 11:35 pm ] |
Have you done any clean-up of that 4bbl museum piece you found during our trip in the snow? Nice collection DusterIdiot! CJ |
| Author: | SlantSixDan [ Sat Apr 19, 2008 6:07 am ] |
Er-ruh...don't know what that Stromburg was originally on, but it wasn't originally on a slant-6. The Stromburgs that went on slants looked like this. The one you've got there looks like an earlier-than-slant design. Any numbers stamped into it? |
| Author: | Aggressive Ted [ Sat Apr 19, 2008 10:41 am ] |
DI, Can you take a picture or two of the Feather Duster carb and post it? Nice idea to show the differences through the years. Good descriptions! Any for sale? |
| Author: | DusterIdiot [ Sat Apr 19, 2008 3:05 pm ] |
| Post subject: | Lol... |
Quote: Have you done any clean-up of that 4bbl museum piece you found during our trip in the snow?
Not yet... his son a 1960 'list-1857' aka Holley 4150E is sitting in teh 'dip at the moment and looks to be a good core for it's age... not sure if the thing would work on a slant, but it is a low cfm 4 barrel, but meant for a Ford 332....Quote: Any for sale?
Yep, I'll be keeping one of the 1973 Holley 1920's and the others I'll look through and be moving along...(and probably a couple of 1945's since some guys on here are having a hard time finding a 'good' reman... and at least I use Standard Hygrade Carb kits when I can get them...) Dan, I'll check for a tag, but I'm thinking this beast only has a casting number on it... since it's family weekend (T-ball went two of 3 innings before the rain/snow thing got the parents whimpering.... Will post more on Monday... I'll also be picking through a box of TQ's (big block), at least one Stromberg WW big block 2 barrel over the next couple of days, and I think I still have a Pinto Weber core to move along... more later, -D.Idiot |
| Author: | THOR [ Sat Apr 19, 2008 6:48 pm ] |
Hey! I recongnize a few of those carbs.... they came from my house!!! |
| Author: | DusterIdiot [ Sat Apr 19, 2008 10:46 pm ] |
| Post subject: | It goes even deeper... |
Quote: Er-ruh...don't know what that Stromburg was originally on, but it wasn't originally on a slant-6. The Stromburgs that went on slants looked like this. The one you've got there looks like an earlier-than-slant design. Any numbers stamped into it?
After doing some hunting and some research, and some cleaning on the top of the fuel bowl... it looks like she's actually a Bendix/Zenith carb Model 228 for use on Industrial/Farm applications (hence the John Deere green...), looks like these are still in use on anything from generators to industrial applications and still installed, according to at least one company site that serviced Zenith, on applications needed a 1 barrel down draft...Guess I'll have to make a backup generator engine for my house incase the power goes out... -D.Idiot |
| Author: | krmilton [ Sun Apr 20, 2008 9:20 am ] |
| Post subject: | aluminum intake |
DI I know this is off topic, but I wanted to ask you, did they make an aluminum intake manifold for a single barrel carb, and if they did, was it on the feather duster. Thanks KR Milton |
| Author: | DusterIdiot [ Sun Apr 20, 2008 9:53 am ] |
| Post subject: | Yes they did... |
Quote: I know this is off topic, but I wanted to ask you, did they make an aluminum intake manifold for a single barrel carb, and if they did, was it on the feather duster.
Yes... the Dart Lite and Feather Duster got a very nice 'cast' aluminum single barrel intake manifold (much lighter than the iron version... and not porous like the E-beam welded late versions of the 2 barrel manifolds)...-D.Idiot |
| Author: | SlantSixDan [ Sun Apr 20, 2008 10:19 am ] |
The 1960-model 170 and 225 engines also got good-quality aluminum 1bbl intake manifolds, either sandcast or semipermanent-mould cast depending which foundry they came from. |
| Author: | Aggressive Ted [ Sun Apr 20, 2008 10:59 am ] |
Quote: Yes... the Dart Lite and Feather Duster got a very nice 'cast' aluminum single barrel intake manifold (much lighter than the iron version... and not porous like the E-beam welded late versions of the 2 barrel manifolds)...
The one I am running now is off a 1980 truck, a very nice casting. It warms up much quicker in the morning and helps with better mileage and performance. It make a bigger difference during freezing and below freezing temperatures. |
| Author: | krmilton [ Sun Apr 20, 2008 1:25 pm ] |
| Post subject: | intake manifold |
Thanks guys, I knew I came to the right place. Anybody got an idea what one is worth? KR Milton |
| Author: | DusterIdiot [ Sun Apr 20, 2008 1:39 pm ] |
| Post subject: | Relative... |
Quote: Thanks guys, I knew I came to the right place. Anybody got an idea what one is worth?
I've seen places ask for about $50 for them, I bought 3 cars with them in it... at swap meets/junkyards if they aren't 'proud' then $15 is the going rate...-D.Idiot |
| Author: | MiDi [ Sun Apr 20, 2008 4:36 pm ] |
wow impressive collection! |
| Author: | DusterIdiot [ Sun Apr 20, 2008 5:04 pm ] |
| Post subject: | You learn... |
Quote: wow impressive collection!
You learn quickly that if you see a pre-80 mopar in a junkyard these days, you learn to quickly grab everything you can, because you may not find what you need later... -D.Idiot |
| Page 1 of 2 | All times are UTC-08:00 |
